highest mileage on 4.2 ??
Old 01-03-2014, 02:59 AM
HankMurphy's Avatar
HankMurphy
HankMurphy is offline
Only 116 thousand miles on my 2008. Got to get out more.
Only major maintenance so far has been brakes.
  #197
Old 01-03-2014, 07:32 AM
offroadnt's Avatar
offroadnt
offroadnt is offline
498654km (309849 miles), just retired her to on farm use and upgraded to a 2010 F250, a truck that's more suited to the job.
  #198
Old 03-09-2014, 08:47 AM
PJ Riggs's Avatar
PJ Riggs
PJ Riggs is offline
I have a 2000 F-150 4.2L w a 5 speed with 220,000 miles with everything factory except spark plugs & wires
  #199
Old 03-14-2014, 01:44 PM
willy j's Avatar
willy j
willy j is offline
178,000 2000 f1504.2 v6
just found a puddle of anti freeze setting on my block underneath the intake, any ideas
  #200
Old 04-02-2014, 09:45 PM
sparkyjj's Avatar
sparkyjj
sparkyjj is offline
WILL NEVER DIE!!
'03 E-150 with 389,xxx on it. Use to be a fleet van and I have had it for 2 or 3 years had to put alternator battery tires gas and change oil otherwise still goin strong. Never has been opened up and had major work done. Use it for my daily driver it gets 17 to 23 mpg average and still pull a trailer full of scrap iron with it. Expect to hit 400,000 by end of summer. My friend drove it daily for his job and we TRIED to blow it up cuz he wanted the company to get him a new one. Nothing like throwing the trans into 2nd at 50+ mph and holding your foot to the floor. No problems with anything on van, all original nothing has been opened up engine, trans rear end, ect.
  #201
Old 04-14-2014, 06:12 PM
XSleeper's Avatar
XSleeper
XSleeper is offline
02 F150 4.2L 5 speed manual... 261,000 and counting.
Recently replaced 02 sensors, cleaned fuel injectors, intake plenum gaskets, valve cover gaskets, throttle gasket, pcv valve and isolator bolts to cure a vacuum leak and now it purrs like a kitten again.
  #202
Old 05-08-2014, 09:16 AM
alpha7mm's Avatar
alpha7mm
alpha7mm is offline
I have 154,000 miles and mines runs quiet when I start it up it has rough idle
  #203
Old 05-28-2014, 11:02 PM
gsmarcano's Avatar
gsmarcano
gsmarcano is offline
I have a 2000, with about 235,000 on the clock and still going strong. But I've always used Mobil one and taken it relatively easy on the old big Blue, as my wife and I like to call it.
  #204
Old 08-04-2015, 10:41 AM
wam92285's Avatar
wam92285
wam92285 is offline
highest mileage
Originally Posted by BrianA
Thanks for the reply...whatever everyone else's experiences, I'm just gonna keep driving and see how long it will go.
Brian
my 4.2 has 342000 on original motor
  #205
Old 08-09-2015, 02:43 PM
Ramiro Saldaña Jr.'s Avatar
Ramiro Saldaña Jr.
Ramiro Saldaña Jr. is offline
High mileage but runs great!!
Originally Posted by LK
Since nobody else responded to your post, here are the only two higher-mileage 4.2L trucks I'm aware of: a '97 with 135,000 miles, and a '98 with 125,000 miles (both are on their original engine). Those are the only two I'm aware of with over 100K...it seems like the 4.2L isn't all that common.
LK
I got a 99' xlt and just went over 270K. Still runs awesome only problem ever had was I replaced the oil pan gasket.
  #206
Old 09-30-2015, 09:11 PM
gsmarcano's Avatar
gsmarcano
252,000 and change.
  #207
Old 11-18-2015, 03:06 PM
Pgh Rebel's Avatar
Pgh Rebel
Pgh Rebel is offline
Got a 2006 here that I ordered because I wanted the 5-speed. Also got the 8' bed, 3.55 limited slip and the towing package. That netted me the heaviest duty 5-speed that Ford would build in that year. 'Course it is 2wd since they no longer offered the 4.2 with 4x4. Anyway got 105,000 on it now and runs like a champ! I fully expect to keep it for another 10 years or more and see 200k at least before retiring it from daily use. The rust hasn't gotten to the body at all, just the bumpers and the steel wheels. I treated that with Rustoleum before it got too bad and that stopped the rust.
  #208
Old 11-19-2015, 01:02 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
Did you change the gasket yourself? I thought the pan gasket on the 4.2 was 2 half moon seals for each end of the pan and a bead of silicone for the rest.
  #209
Old 01-17-2016, 07:15 PM
fordmudtruck27's Avatar
fordmudtruck27
fordmudtruck27 is offline
My 1998 4.2 f150 automatic 2wd has 289,500 miles still running strong no problems original motor and only had rear main seal done to it from my friend i got it from towed 8000lbs skid steerers with it and put 2700lbs in bed best 450 bucks ever spent it needed a rear
  #210
Old 07-15-2016, 06:13 PM
Patriotgrunt's Avatar
Patriotgrunt
Patriotgrunt is offline
Trailering
Just picked up an 03 with 117K. I'm stoked about this truck. It's going to be a great truck.
Quick Reply: highest mileage on 4.2 ??
