AC blower speed?
Nothing is wrong, it is designed that way. It blows harder on Max than on norm setting. Mine does the same thing.
It may be that the fan on the older one is getting plugged.
Maybe I need to read more thoroughy! It may be that the housing has some gunk in it on the weak one, or the motor may be getting tired on it.
Are you getting all 3 speeds from the fan? If not it may need a Heater Blower Motor Switch Resistor.
The HVAC system takes air from outside unless it's in the Max AC mode, then it takes air from inside the truck. The fan doesn't speed up it just moves more air due to less resrtiction. IF you are getting all 3 fan speeds then you may have a restriction in the MAX air intake. It's located at the passenegers feet. I've seen plastic bags get sucked up in there.
If there's no restriction the Air Inlet Duct Door isn't working. It's vacuum controlled. It's behind the glove box IIRC.
raye321
08-01-2014 06:20 AM
Ricky Mayo
09-28-2010 09:05 PM
tripledbucks
10-28-2007 03:41 PM
