It's 7.3 power stroke. It's appears to be diesel I don't know how to be positive other than put oil in the anti freeze and put diesel in it to see the difference.
You should be able to tell if it's fuel by the smell.
Yeah it is a cup, i was told you could do a pressure test with injectors out to see which one it is, but i dont know how to pressure test
You need to remove the injectors & pressurize the cooling system
I have a small hand pump that replace's the rad cap,, puts 15-18 lbs of pressure in the system .The leak should be obvious..You can use regulated air pressure , butyou have to be very carefull not to over do it.....15 lbs is usually plenty....
