Airbag code
Fuse location for Airbag and Horn
Originally Posted by pfogle
That sounds like your clock spring. Does the horn work?
How may I further isolate the issue, other than presumption of Clock Spring as self-fix of that issue is not one I will tackle, which means $$$ for dealer to do the job. I don't need to go through vehicle inspection until this time next year, so I have a little time to procrastinate further, and am hoping a different fix may be discovered... For instance, I can pull a fuse, and get it checked; even replaced...if I knew which one, or knew where to download a fuse box 'diagram'. 2000 E250 Cargo van.
Thanks. All input welcome.
Originally Posted by JohnMcHugh1
My Airbag ikon flashes "32", and has done so for months. No horn, although I believe initially I had use of the horn, and still saw the Airbag lamp on. My Cruise Control is a 'stem' off the steering column, works well, and must be non-Ford original unit.
41 is a primary crash sensor #1 circuit open. That should be the one in front of radiator. Make sure it's there and plugged in.
