tune up question ford f250 sd 5.4L
Old 10-05-2001, 03:03 AM
gtex's Avatar
gtex
gtex is offline
Old 04-12-2002, 06:03 AM
gjvoight's Avatar
gjvoight
gjvoight is offline
Recently purchaced a 99 f250 sd 2wd with 107,000 miles. Can anyone recomend what plug wires I should replace the old ones with, are the bosh premium plugs worth the money, and beside the o2 sensor what else should I replace?
George
Old 04-23-2002, 01:20 AM
hood's Avatar
hood
hood is offline
gjvoight:
I would suggest using Motorcraft wires. Spark plugs are a toss up. Most folks say to use the Motorcraft platnium plugs. I personally have had very good results with Bosch platniums. Just remember to gap them correctly and to use dilectric grease on the plug boots.
Tune-up parts:
-PCV
-Air Filter
-Fuel Filter
-Wires
-Plugs
-hooD
2002 F-150 4x4 REGULAR CAB
DARK SHADOW GRAY CLEARCOAT
XLT 139" WHEELBASE STYLESIDE
5.4L EFI V8
ELECTRONIC 4-SPD AUTO O/D
3.73 RATIO LIMITED SLIP AXLE
SKID PLATES
7700# PAYLOAD GROUP
TRAILER TOWING GROUP CLASS III
LT245/75R-16D OWL ALL-TERRAIN
BUILT FORD TOUGH!!!
Old 01-03-2011, 10:22 AM
whitsitt3's Avatar
whitsitt3
whitsitt3 is offline
Originally Posted by hood
gjvoight:
Tune-up parts:
-PCV
-Air Filter
-Fuel Filter
-Wires
-Plugs
-hooD
5.4L EFI V8
SKID PLATES
7700# PAYLOAD GROUP
BUILT FORD TOUGH!!!
Hood, what is the purpose of dielectric grease? Is your list complete? I'm getting ready for a tuneup on my 99 f250 sd as well and wanted to make sure I had all the correct parts.
Old 01-03-2011, 02:24 PM
guitar maestro's Avatar
guitar maestro
guitar maestro is offline
dielectric grease helps keep moisture out, so it rules out any possible oxidation of the metal contact parts
plug wires: I've used Motorcraft and FRPP
plugs: I use Autolite Coppers since I don't mind changing them once a year. For extended use, Autolite double platinums work very well for extended intervals. make sure to only remove the plugs when the engine is cold so you don't yank out or damage the threads in the heads. Use anti-seize grease on the plug threads before you put them in.
buy a tamperproof torx bit set with a T-20 bit to remove the mass air meter from it's housing and clean it with maf cleaner spray or electrical parts cleaner. TCCoA Tech Articles
flush the cooling system with prestone system cleaner, and then with distilled water + antifreeze. Replace the coolant reservoir cap with a new oem motorcraft one. Replace thermostat and Tstat O-ring
drain the transmission fluid and drain out the torque converter. Replace transmission fluid filter and refill with mercon-V trans fluid.
Drain and refill differential.
thats what I would do in addition to what already has been said.
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Roachfood
03-11-2002 10:21 PM
Quick Reply: tune up question ford f250 sd 5.4L
