Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-08-2007, 06:48 PM
Tom D Tom D is offline
Garage is empty, add now
Tom D is starting off with a positive reputation.
water/alcohol injection systems
I just finished reading with great interest about the water/alcohol injection systems. Sounds a lot safer than propane injection and easy to install. I presume it would work well with Bio as well as Dino. Would you experts check it out and let us know? www.alcoholinjectionsystems.com I would like to install it on my Turbocharged IDI 7.3. Any comments would be greatly appreciated. Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
  #2 (permalink)
Old 08-11-2007, 07:56 PM
Quote:
I'm amazed no one replied to my post. I figured Fabmandelux would at least say whether it works well with biodiesel. Hasn't anyone had any experience with water/alcohol injection systems. Come on guys give me your 2 cents worth.
__________________
  #3 (permalink)
Old 08-12-2007, 06:33 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
I've seen a 15% alcohol/water mixture make 50 HP on a turbo IDI on the dyno. It made somewhat less than that on my truck.
If you're going to do it, I would reccomend using a small nozzle at high pressure for better atomization, and don't trigger the system on below about 75% of your peak boost.
Also, use only distilled water in the system. I ran tap water or winshield washer fluid when my system was installed and the deposits in the intake were readily visible when I pulled that motor apart. Given enough time those deposits might have caused some damage.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #4 (permalink)
Old 08-13-2007, 10:50 AM
AIS AIS is offline
AIS is starting off with a positive reputation.
I thought since this thread was asking about our system I would post this here:
If you're interested in learning more about our system hkiefus (an FTE moderator) has purchased the system and will be posting more info as he installs it in this thread: http://www.ford-trucks.com/forums/63...n-finally.html
He already has his own pictures of the system up in the thread.
If you prefer, you are more than welcome to direct any questions you have to me as well.
- Nathan
Tags
20, 54, alcohol, alcoholism, chat, diesel, f250, fluid, injection, meth, peak, powered, propane, systems, vbulletin, washer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
