Interested in Water Injection
Old Aug 29, 2007 | 10:08 AM
AIS's Avatar
AIS
We've received several questions about our systems here on FTE. I thought it would help others with similar questions if I posted some info from our website. So here it is
No supercharger or turbocharger system is complete without a water methanol/alcohol injection system. Whether or not you are running an intercooled system, the benefits gained from water injection are so profound you simply can't afford to run without it. The best part is that these benefits can be realized in less than an hour... the time it takes to install our system.
Water Alcohol/Methanol Injection Will Reduce Your Air Charge Temps and Provide the Following Benefits:
Our trunk mount kits make it easier than ever before to install. Unlike other systems, you won't have to worry about assembling the components first and then trying to find space to install the pump, container, hoses and wiring under the hood of your ride (nearly impossible on newer vehicles). This can be time consuming (between 4-6 hours) and costly (mechanics can charge $100+ per hour). Our trunk mount systems are typically installed in less than an hour!! That's because our system comes pre-assembled. So the only thing you'll have to do is install the tank assembly, injection nozzle, and the fluid lines connecting the two. You WON"T need to remove your bumper or fabricate mounts in your fenders!! We even provide you with REAL installation instructions, not some generic steps that were haphazardly put together.
Compare our trunk mount systems to the competitors systems and you'll quickly see the difference!
Our Kit vs. Leading Competitors:
  • Most advanced digital progressive controller on the market - compare for yourself vs. the competitors
  • Our all-in-one controller allows you to run not only a boost signal but also a MAF, TPS, MAP & EGT signal
  • System includes a serial port for connection to a laptop
  • System comes pre-assembled unlike the competitors which requires you to assemble everything
  • System can be installed in 45-60 minutes - That's 5-9 times faster vs. the competitors under hood kit
  • No unsightly pump, reservoir, hoses or added wiring under the hood
  • No need to convert existing wind shield wiper fluid container
  • Our system is completely hidden in the trunk for a stealthy install
  • 1.5 gallon container vs. the competitors common 1-2 quart container
  • Much less frequent refills required as the leading competitors do
Have questions or need help choosing the right water methanol/alcohol injection system for your application. Gives us a call toll free for immediate service at 1-801.447.ALKY (2559)
Stage 1 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System
Stage 2 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System
Old Jan 6, 2008 | 07:37 AM
misnomer's Avatar
misnomer
How do you size water injection systems? Displacement? HP output? Torque?
On a 6.9L IDI Diesel with 10-15 psi boost, would there be a measurable benefit? and what volume nozzle(s) would be recommended/required for this application?
aurgathor
Alternative Fuels, Hybrids & Mileage
47
May 20, 2013 12:25 AM
SuperSnake
Nevada Chapter
Apr 10, 2008 12:57 AM
Strictly Diesel
Vendor Specials, Discounts, Product Announcements & Group Buys
May 18, 2007 01:07 AM
tomoto
21
Mar 4, 2007 11:05 AM
