Speedo Correction on 08's
Originally Posted by skl
I'm surprised how close the speedo is with my OEM 20's. I have a new Garmin Nuvi nav system which shows your speed real time and the speed is nearly spot on. My regular cars are mostly German and they always run several mph fast...
dealer can only calibrate between the OEM tire sizes...ie I can switch a superduty with 18" wheel configurtions to the calibration of a superduty that has 20". This will help in some instances and that is what we have been doing but we have a lot of trucks running around with 37" and 40" rubber and there is not enough play in factory settings to get the speedo close.
Yes the majority of tuners can calibrate for tire size but I know SCT for sure is only releasing base programs and not doing any custom calibrations such as tire size etc right now...it's coming, but its not available yet.
Originally Posted by Matt99DECH
what devices are you guys out there with lifted trucks/bigger tires using to correct your speedos?
Matt
Matt
mstwhodat
05-04-2011 08:56 AM
iwannanSC
22
07-15-2009 11:46 PM
///M Puller
1999 to 2016 Super Duty
08-30-2008 07:01 AM
