6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Speedo Correction on 08's
Old 07-25-2007, 05:51 PM
Matt99DECH's Avatar
Matt99DECH
Matt99DECH is offline
what devices are you guys out there with lifted trucks/bigger tires using to correct your speedos?
Matt
Old 07-25-2007, 09:31 PM
spatel23's Avatar
spatel23
spatel23 is offline
you can get your dealer to recalibrate for larger tire sizes and they can get it pretty darn close. From what I hear within 3mph. Im sure theyll get closer with time.
As far as a tuner goes pretty much all of them recalibrate for tire size.
SCT is the way to go
Old 07-25-2007, 09:59 PM
skl's Avatar
skl
skl is offline
I'm surprised how close the speedo is with my OEM 20's. I have a new Garmin Nuvi nav system which shows your speed real time and the speed is nearly spot on. My regular cars are mostly German and they always run several mph fast...
Old 07-25-2007, 11:32 PM
SpeedE55's Avatar
SpeedE55
SpeedE55 is offline
At the risk of sounding like Captain Obvious, The wheel size can change without it affecting your speed if the overall wheel/tire diameter doesn't change. You can have an 18" wheel with a taller sidewall tire vs. a 20" wheel with a lower profile tire, and the ycan bth have close to the same overall diameter.
Old 07-26-2007, 07:24 AM
Matt99DECH's Avatar
Matt99DECH
dealer can only calibrate between the OEM tire sizes...ie I can switch a superduty with 18" wheel configurtions to the calibration of a superduty that has 20". This will help in some instances and that is what we have been doing but we have a lot of trucks running around with 37" and 40" rubber and there is not enough play in factory settings to get the speedo close.
Yes the majority of tuners can calibrate for tire size but I know SCT for sure is only releasing base programs and not doing any custom calibrations such as tire size etc right now...it's coming, but its not available yet.
Old 07-28-2007, 11:46 AM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
Matt
If you dont want to spend alot of money on a tuner, Superchips sells a programmer to adjust the speedo for larger tires. I think it's around 250.00 or 300.00 dollars. I think it will raise the top speed cut out to.
Flip4ford
Kansas Chapter
43
07-26-2018 06:43 AM
mstwhodat
05-04-2011 08:56 AM
iwannanSC
22
07-15-2009 11:46 PM
///M Puller
1999 to 2016 Super Duty
08-30-2008 07:01 AM
pashtrd
02-20-2003 10:15 AM
Quick Reply: Speedo Correction on 08's
