Will the 164 tooth flywheel out of a 1987 injected Bronco have the right balance for a 1986 carb'ed 351W from an F250? The 302 flywheel has the numbers E1TE-AA and 5K18 on it. Everyone I ask around here starts rattling on about 5.0 roller motors out of Mustangs which does me no good.
Go to the local parts store that sells flywheels and ask them for each one and see if they give you the same flywheel. If they stock different flywheels you will have your answer.
