Rear Pass Door Lock 01 Exp
There is an aluminum rivet that holds the actuator to the door. It is common for them to corrode or fall out. When you open the door look at the painted part a few inches below the lock mechanism catch, you should see an aluminum rivet about the size of a nickel. If you see just a hole the actuator is flopping around and needs to be rivetd back to the door. Compare both back doors to see if one has the rivet and not the other.
SteveL53
Electrical Systems/Wiring
07-26-2016 08:53 AM
MisterMoad
07-19-2016 02:15 PM
Crewcabber
10-15-2015 12:15 PM
akfcc350
08-25-2005 12:29 PM
