injection pump remaned OR rebuilt?
Am getting my injection pump rebuilt here in Albuquere by a reputible diesel shop they specialize in light duty diesel trucks, parts labor will be at around $900.
I am tackling the injectors myself this weekend which I got from them also the kit suprised me they went thru on explaining on what to do and watch out for when I picked up the parts.
Any opinions as to which way to go? Starting to have second thoughts on the rebuild on different sites I see IP's for $400+/-
The price does look real high. I paid $450 each for the last 2 IP's I got rebuilt and calibrated for 6.9 turbo.
The shop had been around for years and the owner (Joe Bradley) was one of the best on pumps, injectors and turbos that I have seen. I really hated to see him close up and move to Oregon
you can get a good rebuild g code pump for about $480 at http://www.mwfi.com/dieselPage/ford_73.htm they have great service and ship very fast. then if your mechanically inclined you can change it your self
In regard to differences between "reman" and "rebuild." There is no difference (in my experience). Anybody can call something whatever they want. The reality is this. The largest and most esxpensive part in a rotary Stanadyne pump of any model is the head & rotor assembly. This is the part the gets trashed when a pump siezes, and if it's even a little wear you'll have a pump that won't start hot. Basically, it is the heart of the rotary injection pump. And, it is NOT cost effective to replace it and there is NO process to renew it or "rebuild" it. So, when you buy an exhange pump, often you will NOT get core credit unless the head & rotor in the pump you trade in - is good. Nobody can make money selling "rebuilt" pumps that have new head & rotor assembies if the selling price is $300-$400. Back in the early 80s, I paid around $300 for new head & rotor from Stanadyne, and at that time I could buy a brand new complete injection pump for around $700. Exhange pumps then were priced around $275.
In just about any pump you buy - called "reman" or "rebuilt", it will have an old, used, head & rotor assembly. The only exceptions would be - that I can think of - is when you ask for, and pay for a new head & rotor that is likely to add $300 or $400 to the price tag. Many shops used to do things as thus. They'd take in any pump on exhange - siezed or not. They'd make enough money on the good pumps that got traded in, that they could afford to put a new head & rotor in a few, once in a while and all balanced out.
In most cases - an "reman" or "rebuilt" pump gets a $15 seal kit, a $8 drive bushing, maybe a new $10 metering valve, new $15 pump vanes and liner, and that's about it - unless it's a pre-1985 pump. If it's a pre-1985 it will also need a $35 EID update kit for the governor assembly.
With injectors - they can be made like new by installing OEM replacement nozzle tips that cost around $8 to $10 each. When you buy exchange "rebuilt" injectors, they should have brand new tips installed. Watch out for a few people selling injectors that are marketed as "rebuilt" but actually have NO new parts. There are a few dealers on Ebay doing that.
ALL-SEASON'S
16
02-15-2019 10:59 AM
R1racer
18
03-31-2017 10:39 PM
SWMO F-350
03-27-2010 07:46 PM
deleontow
05-24-2006 06:42 PM
