transmission problem
Old Jul 13, 2007 | 07:45 AM
hungry_aggie's Avatar
hungry_aggie
Question transmission problem
I have a 94 4x4 crew cab 7.3 idi turbo. yesterday on my way home from work the transmission statred to shift hard and the overdrive off light on the column shift lever started blinking still goes into over drive but shifts very hard and almost red line before each shift. also the blinkers quit working at the same time. Does anybody know what could cause this Please help.I looked at all the fuses and made sure they were good and not looose.
Old Jul 13, 2007 | 05:20 PM
bobpat204's Avatar
bobpat204
was the tach and speedo working normal? also did the abs light come on?
Old Jul 13, 2007 | 11:07 PM
KJLYPW's Avatar
KJLYPW
Three main components to make sure are working correctly, the tach, the vehicle speed sensor (on top of the differential) and the FIPL sensor on the side of the injector pump. Check for loose or broken wires, corroded connections. If tach and speedometer are normal, the FIPL could be the faulty part. See post under Hard shift for info on checking the voltage output on the FIPL, should be 1.05 to 4.3max with no dead spots between idle and wide open position, key on engine off check.
If that isn't it you will need to get a Ford OB1 code reader and check for fault codes, cheap- 30 dollars at Walmart with book, codes, etc.
Old Jul 14, 2007 | 01:49 AM
crazymike's Avatar
crazymike
hmm now that i think about it the day we destroyed the tranny in mine the fuse for the emergency lights burned out? -think that its connected?
Old Jul 14, 2007 | 03:08 PM
KJLYPW's Avatar
KJLYPW
Bad grounds on your lights will tell the computer your brake lights are on, unlocking your torque converter, electrics can do strange things when all is not as it should be!
