Manual transmission
Originally Posted by Kane150
Hey PeopleI have a 1989 F150 4X4 v8 with a bad manual transmission. What years will fit my truck? any help is appreaciated.
When you say bad, what does that mean?
Grinding when shifting = Worn syncros can be replaced. 3 or 4 speed. All it takes are the syncro blocker rings, the shoes for the syncros, a small parts kit, gasket set and two seals. Make sure before doing anything, the clutch itself isn't the problem.
This is a diagram of the Mazda 5 speed also called the M5R2 used on trucks. There is also a M5R2 that was used on the T birds that used a different shifter but shared some of the same parts as the trucks.
Figure 104 and 106 are black plastic bushings that usually crack and wear away.
You can purchase the bushings on Ebay. Ford may still sell them.
Remove the shifter boot and pull it up on the shifter shaft. You'll see 3 small torx bolts. Place the trans. in neutral. Remove the 3 torx bolts. Pull up and the shifter lever will come right out.
Look right below the two pins that are pressed into the top of the side cover. (figure 68 shows one of the pins) Right below will be one of the bushings. The other bushing will remain on the shifter shaft. It's possible bad bushings are causing your problem.
nevergivenup123
19
03-22-2016 08:04 PM
rkmason
03-01-2016 09:44 PM
kvillecomet
04-22-2009 08:58 PM
Bob Crain
06-19-2005 01:15 AM
