New Owner/ Rear Window Question.
Ok, so my fiance's dad has had an '85 Bronco sitting at his house for as long as I've know her. So finally I asked him about it and he quit driving it b/c the emissions bs is all screwed up/broken off at the manifolds etc. Anyway he gave it to me today and I'm going to pull the 351 to rebuild and put in my '71 f100 and replace it w/ a 302 I have. My question is about the rear window. With both the inside switch and the outside key switch I can hear the motor running both up and down but the window does not move. I ran out of daylight today and didn't get to look into it. Are the tracks/gears easy to get to/work on/repair? And what do you guys suggest the problem is?
Any help is appreciated.
Yep the gears and such are pretty easy to get to. There is a access panel on the tail gate on screw it and you will be able to see everything. If the window is up (and I assume and hope it is) then you'll be set my bet is the gears and guides are rusted and the window is stuck, you'll be able to see everything as long as the window is UP.. If the window is down you need to CAREFULLY raise the window manually so you can get to everything.
Good Luck and welcome the the forum.
with the gate down pop things on the side so it thinks its closed open your acess panel and from the switch roll the window up and have someone back there to support the glass as it comes out.
boice, dont put a 302 into this bronco. i strongly suggest you leave it in there as is and get it running. the bronco is a heavy rig and the 302 will leave you wanting more.
GamerGirlAlice
08-04-2013 10:24 PM
bucks77ford
02-05-2008 07:21 PM
Daddywags
15
11-14-2005 08:54 PM
