1978 - 1996 Big Bronco
96 FSB wheels
Old 07-01-2007, 09:46 PM
fillbilly's Avatar
fillbilly
fillbilly is offline
96 FSB wheels
Does anybody know what other vehicles have the same lug pattern and how large of wheel/tire I can put on a stock 96 FSB
Old 07-02-2007, 12:25 AM
sirkt's Avatar
sirkt
sirkt is offline
Any Ford wheel from at least 1973 to 1996 will fit on the bronco. The lug pattern is 5 on 5.5 so wheels are easy to find. I run 31x10.50s on by stock bronco (92) so I know they'll fit.
Old 07-02-2007, 07:05 AM
lostin90s's Avatar
lostin90s
lostin90s is offline
Some Scout ,jeep (to mid 80's )dodge (if center hole is big enough) Will bolt on and I have used them all on trucks from 76-96. Most latter jeeps were almost identical to 80+ ford rally in looks except center cap. Most 80's dodge rims seemed weak and rust prone. But If you get after market rims they will be Ford, Dodge , And jeep bolt pattern.
Most stock rims are 7" or 8" you can run 31/10:00/15 or 265/75/15 easy and were stock issue on some . May rub on arms no biggie.
32" tires will fit on stock suspension but if you flex truck wrong (pull into parking lot that is higher than road) you may have some rube issues.
Good luck
Old 07-02-2007, 06:41 PM
aurgathor's Avatar
aurgathor
aurgathor is offline
No one mentioned it yet, even though there are many 5 by 5.5" wheels, they may not have the same BS. (BackSpace) or offset. You need to have around 3.75" BS; the proper BS is more important with wider tires.
Old 07-03-2007, 04:26 PM
FarmForward's Avatar
FarmForward
FarmForward is offline
My '96 EB Bronco has the stock aluminum wheels, and I have 31x11.50x15's on them that fit with no problem. I can't recall a time they ever rubbed, although most of the driving I do with it is on hard surfaced roads.
Old 07-03-2007, 06:01 PM
NWBronco's Avatar
NWBronco
NWBronco is offline
Any thing 15" Ford 5 on 5.5". '73 year may be dicey. You need to make sure it came off a 4WD rig. (Spindles were way smaller on the cars). Stock rims were 7 to 7.5" wide, 3.5" back spacing. As far as what max tire size, it's a crap shoot. Worn shocks and springs will shrink the max size a bit. Find a bud running something you like. Ask him to swap 'em to your rig and see how they do.
Bob
Defyant
Maryland Chapter
11-02-2012 11:07 AM
wetneck
15
08-26-2010 05:00 PM
khadma
02-17-2009 10:32 AM
khadma
02-09-2008 09:15 PM
khadma
10-13-2007 07:02 PM
Quick Reply: 96 FSB wheels
