Window won't go up!
Window won't go up!
The passenger side rear window has always been slow to go up, and now it won't move without help. It's also crooked now (lower in the front).
I did a quick search and didn't come up with anything helpful. Anyone know how
to fix this? The motor seems to be working okay, the window seems to just be sticking. Thanks!
Yea there are bushings that slide up and down a post inside the door I believe. Been a while since I've been in the door. They're plastic and usually break off causing the window to pitch back and forth. Also if your window channel guide is worn out ( no felt left inside it ) it'll grab the glass and make the situation worse. Good luck.
Take a look here:
https://www.ford-trucks.com/forums/4...sh-window.html
A little silicone grease will do wonders for the windows.
shotgunner426
10-03-2003 04:06 PM
