Rear End Repair
Rear End Repair
I have an 04 f150 screw with 20000 and I already need rear end work on it. I bought it used from a guy and I dont think anything bad has ever happened to it. I took it up to the dealership and talked to the service manager and he says he will do everything he can to help me with the price and my problem. If I do get a reduction in price can I trust these guys to do a good job and replace everything that needs to be replaced?
If it only has 20,000 miles I would think it's still covered under the warranty, Unless not, because your not the original owner ? I think there is a TSB on the posi rears. mine started making noise, all i had to do was change the fluid and add some posi additive. It's been fine since. Only after, did I find out it WAS covered under the warranty
Chanticleer
10-13-2005 07:59 PM
