51 clearence/signal conversion
has anyone been able to get rid of the fender mounted front signal lamps, and combine them with the clearence/park lights?
I have purchaced sockets from D/C to take the standard 1157 bulb, but there is not enough room for the socket and the bulb!!
If the socket is seated in the lamp assembly it will fit into the lower vallence under the headlight bucket...But the bulb sticks out to far and the lens will not fit...I could push the socket back inward enough to make the bulb just clear the lens, but then the j-slots in the socket are exposed to moisture, and the bulb will probably melt the lens eventually...
Verry frustrating
Solutions and ideas would be verry welcome.
Thanks in advance
oilyowl.
Verry frustrating
Thanks in advance
oilyowl.
kailor
1997-2006 Expedition & Navigator
06-29-2011 10:46 PM
