Cam Break In Article
Old 06-09-2007, 08:11 PM
petes79f150's Avatar
petes79f150
petes79f150 is offline
Just out browsing, and came across this article with comments by who other than Survival Motorsports (and FTE's) own Barry R. in Hot Rod.
Not new info, but worth reading, IMO. http://www.hotrod.com/techarticles/e...ech/index.html
Pete
Old 06-09-2007, 11:16 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
It is not too old. It is very good info. You might check and see if that has been linked to in the Oil forum. Probably has been as there have been a number of discussions on that subject there. If not, a link there may be a good idea also.
Old 07-08-2007, 01:35 PM
rkymtnman30's Avatar
rkymtnman30
rkymtnman30 is offline
Great article
Great article thank you for posting it. I have a question maybe someone has a answer for I am rebuilding my 351W and changing the cam to a comp cam #35-255-5 and was thinking I would need to change the valve springs for this change but I am haveing trouble finding a spring set for this cam I keep ending up at stock springs does anyone have an idea of where to find the springs for this cam or are the stock springs the correct springs for this cam?
Old 07-09-2007, 12:56 AM
mark a.'s Avatar
mark a.
mark a. is offline
Reed cams has a supply of good lifters, Johnson, Federal. I didn't use the lifters that came with my Lunati cam I didn't feel as though it was worth taking a chance considering how much damage they could do.
Old 07-09-2007, 10:51 AM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
I knew I used Rotella for a reason!
Old 07-09-2007, 05:42 PM
petes79f150
rkymtnman- I see the Comp spring # 942-16, or the 972-16. Different installed hgts, and a little different spring rates. They use those on a bunch of cams. In fact I've got 'em going in a 310" with the 268H hyd. flat cam. Different I.D. and O.D. also. Let me know if you need exact specs.
Pete
60RatRod
42
09-18-2010 10:59 PM
highteckredneck
1997 - 2003 F150
04-19-2010 06:51 AM
4tl8ford
03-25-2010 06:10 PM
bio-d
07-06-2008 02:09 PM
hollenjoe
17
03-20-2008 02:47 PM
Quick Reply: Cam Break In Article
