1954 F-600 Fuel Sending Unit
It depends if the sending units are the originals. Ford replaced ALL the 6 volt senders (car & truck) from 1940 thru 1955 with one part number in 1955 = B5AF-9275-A. This sending unit did not come with the arm and float, it was transfered from the old to the new. The F1/100 thru F3/350 original senders were: 21C-9275-B. The F4 and larger trucks except cabovers were: FAC-9275-B.
So, if the senders are original, they won't interchange. However, while B5AF-9275-A is obsolete, the ORIGINAL 1940 sender (01A-9275) has been reproduced, and with it, your original arm and float can be transfered over.
cbquinn66
04-04-2017 12:03 PM
