I put a sending unit in the rear diff cover.
Hey guys!
Thanks to Alan's generosity, I've connected a second sending unit to my trans temp gauge. I didn't like the factory port on the top of the Mag-Hytec cover so I just drilled and tapped where I thought it should be.
Items used:
Single Wire Sending Unit (Alan sent me his extra one)
SPDT Switch mounted on the dash
20+ feet of 18 gauge wire
Connectors (crimp style, but soldered)
11/32 Drill Bit
1/8" NPT Tap
Drill (I used my mill)
Now I can flip the switch on the fly and see what the rear diff temp is.
Items used:
11/32 Drill Bit
1/8" NPT Tap
I'm thinking that adding a braided ground strap somewhere to allow a "good" ground for the rear-end assembly wouldn't be a bad idea to insure reliable readings.
Think about it, the springs have rubber bushings in the shackles, the shocks are set in rubber, the brake line is rubber, and that only leaves the drive shaft, which is rotating through greased needle bearings, as the ground. All steel, but nonetheless, not a good ground.
I'm not sure how the VSS accomplishes this, but it's two-wire for a reason, and the ground may be floating for it.
Pop
Pop
Originally Posted by mustang_gt_350
any temps yet? daily driving? pulling? Just wondering as i have no idea of what temps they normally run
The sending unit has to match the gauges that is is hooked with..The diff temp takes a good 20 minutes of highway driving before it comes up to about 250 degrees, it will be your hottest temp gauge you have. Once it gets warm the temp shoots right up. I haven't seen anymore then about 260 degrees.
I took my stock diff cover and tapped it and installed a sending unit and have it wired in..It is one of the last gauges I have installed on my truck, last count was 10 gauges..
Cool idea. Not to rain on anybody's parade here, but I have to ask, are these sending units thermistors, or thermocouples? If it is a thermistor, you should be fine going through a switch, but if it is a thermocouple, there could be a problem.
Thermocouples work by measuring a voltage generated by two wires made of dissimilar materials coming into contact. Usually, the equipment they are connected to has terminals made of materials that either won't generate another voltage, or will generate an appropriate voltage that can be accounted for via the calibration of the meter. If you put some random switch in the line, without knowing what the terminals are made of, you can affect the calibration of the meter significantly. This is not a problem with thermistors, because they just change resistance with temperature, they don't actually generate a voltage like a thermocouple does.
I am not familiar specifically with the sensors you're using, but just wanted to bring this up as a general point that should be considered. Maybe someone here who is familiar with these gauges and also with thermocouples could address this. I hope it works out for you.
