6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Hesitation on takeoff help??
Old 06-04-2007, 02:34 PM
chi6488's Avatar
chi6488
chi6488 is offline
My truck has about 35 miles on it. I picked up the truck Friday and have driven it once since I brought it home. I noticed this morning that is hesitates on takeoff. Thought maybe it was cold, got to the office and turned off for a few minutes. Drove to bank and was still hesitating when I take off. Mondays are bad days at the dealer so maybe tomorrow or wednesday I will take it in. Not happy for a brand new vehicle.
08 6.4 250 cc 4wd king ranch
Old 06-04-2007, 03:21 PM
blackhat620's Avatar
blackhat620
blackhat620 is offline
Sounds like normal turbo lag, and an engine that is not broken in yet or beyond its de-powered initial break-in phase. Also the PCM has not learned your driving style yet. You are always going to have some turbo lag however.
Hope this helps
Old 06-04-2007, 03:26 PM
ag-ford-4x4's Avatar
ag-ford-4x4
ag-ford-4x4 is offline
Man...where did this 'de-powered break in phase' thing start? From my understanding, this does not exist.
Old 06-04-2007, 03:45 PM
blackhat620
With the introduction of 2008 trucks and the 6.4L. There have been other threads on it, this has been verified by vloney & BowTieHtr. It seems FMC wants the engines to break in properly before people start towing 10K pounds at full throttle up a 7% grade.
Old 06-04-2007, 04:23 PM
GMtoFord's Avatar
GMtoFord
GMtoFord is offline
Drive it and dont worry about it,it'll break in and get better. Give it some time.
Old 06-04-2007, 05:24 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
SouthTexasDiesel is offline
Like everybody's been saying, just give it some time. I wouldn't worry about it giving you a little bit of lag when it's got only 35 miles on it. I let my F-350 get about 2000 miles on it untill I started planting the foot down, and it felt like it had more power and response that any of the truck I drove that were on the lot. It should get better, just let her break in.
Old 06-04-2007, 06:36 PM
mikey2000's Avatar
mikey2000
mikey2000 is offline
There is no "break in tune" and there is no turbo lag because the 6.4s are twin turbo. The small turbo gets out of the hole and then the big turbo takes over. Go get it checked out by the dealer. My 450 is a hot rod. There is a lag between 1st and 2nd when you punch it.
Old 06-04-2007, 06:40 PM
SuperDutyJ4500's Avatar
SuperDutyJ4500
SuperDutyJ4500 is offline
Drive it more, and see what happens. You cant expect the truck to be a rocket with only 35 miles on it..everything is not seated correctly at this point. Give it more time, it will get better.
Old 06-04-2007, 06:46 PM
vloney's Avatar
vloney
vloney is offline
Small little thing you can check before you go in.....Have someone inside the truck, while you look under the hood at the vgt actuator (a rod about 3 inches long, roughly to the left of center by 6-8 inches) When they simply turn the key on, the actuator should cycle full on, and full off. This is to prevent vane sticking (the problem with the 6.0). If it doesn't, that would be a problem with boost (it should set a dtc if it is bound up). I do however think it is in the "de-powered" phase of the breakin. Our car hauler at our dealership, when it got over this period, became a powerhouse monster. Pulling 32,000 pounds regularly, 9 mpg doing it. Set the cruise with this weight in St. Louis, Mo. Drive to our dealership (139 miles), several hills, NEVER KICK OFF THE CRUISE! 08 F350 6.4 automatic.
Old 06-04-2007, 06:51 PM
SuperDutyJ4500
That sounds awesome vloney...never kicking off the cruise up those hills, thats what I like to hear.
Old 06-04-2007, 06:54 PM
mikey2000's Avatar
mikey2000
Vloney, when is the motor broken in and the supposed de-tune go away?
Old 06-04-2007, 08:40 PM
chi6488's Avatar
chi6488
chi6488 is offline
To be honest with you guys I don't dog my vehicles. Not that I baby them but I deal with insurance so I experience all types of claims. I drive normal and not like I stole my truck. The hesitation I feel is just from normal take off.
Old 06-04-2007, 10:37 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
bet you its just the electronic throttle, since its not a cable, my dads f150 has a slight hesitation, took it in, the techs said that they all have the same thing, could be he was blowing smoke up his *** but i do believe it
Old 06-05-2007, 08:02 AM
vloney's Avatar
vloney
vloney is offline
give it a couple-three hundred miles. Originally, we were told 2 obd2 drive cycles, but I have been seeing it take a little longer, depending on driving styles,fuel quality, frequency of loading, and weather.
Old 06-05-2007, 08:33 AM
vloney's Avatar
vloney
vloney is offline
Be mindful, however, that when you are going through regen, power is reduced. When you experienced this hesitation, it wasn't regenerating, was it?
Quick Reply: Hesitation on takeoff help??
