Water Pump on Flat 6
Old 05-29-2007, 11:23 PM
RedSkin12B's Avatar
RedSkin12B
RedSkin12B is offline
Quick Question:
I know this may sound like a silly question, but lately I'm hear'n a metalic sound from the front of the engine and I'm wondering if the water pump has bit the dust....did have an aftermarket temp. gauge....I put a thermastate (SP) in and it quit working I think... I know the engine is supposed to run alittle hot... just wondering if that's what it might be or is it something more serious.
Brad
Old 06-08-2007, 10:24 PM
Snowking's Avatar
Snowking
Snowking is offline
I would agree and say it wouldn't be too serious worst case scenario replace water pump and flush the coolant system.
Old 06-09-2007, 11:13 AM
RedSkin12B's Avatar
RedSkin12B
Well I ordered a water pump rebuild Kit and waited for it to come in before tear'n in the the water pump on my flat 6. I took it off and inspected the water pump and it looked Good and when rotated by hand was quite. So I'm think'n its a lifter or valve in the first cylinder now... one of these days I'll figure out how to put a little video up with sound..bet that would help. Thanks for the reply.
Brad
Old 06-09-2007, 07:16 PM
RedSkin12B's Avatar
RedSkin12B
Here, I did what I saw done on here before and put a video of the sounds I'm hearing on Youtube--- http://www.youtube.com/watch?v=V7EhXtCG31Q That is the link to it...take a listen and tell me what you guys think. Thanks
Brad
Old 06-09-2007, 09:23 PM
Snowking's Avatar
Snowking
Snowking is offline
Nice to see a flat 6 runnin even if sickish, first one I've seen believe it or not.
Well sure you're curious to find out what me thinks.
I don't know if you have pointed the problem noise to the front part of the motor but My vote is on your clutch/flywheel assembly.
How you ask, I am going to say something is loose and when the motor is reved from a idle pressure builds and the "knock" stops.
My secound guess would be a lifter assembly but I do not think so the Knock sounds to loud that SERIOUS damage would be occuring to the valvetrain.
My 2 cents anywho
I'm pullin for ya though just glad to not see any valve covers lol
Old 06-23-2007, 10:27 PM
flat6inline's Avatar
flat6inline
flat6inline is offline
1950 226 Flathead Ford water pump
Hello, everyone.
Can anyone help me in knowing where to find a water pump for the 226 Flathead six motor ?? This is all new to me. I bought a 1950 226 Flathead six motor. and before I mounted it in my RatRod I wanted to know, if this motor would run. I took out the plugs and it turned over easy. I had great compression on the first 4 cylinders from front to back , but the back two cylinders had none. I took off the intake and the exhaust manifolds and then the side cover plates. and found that the back two cylinders had the exhaust valves stuck open. I took the head off. and found the head to have just been worked on , and the cylinders still had the honing marks in them, Everything was perfectly clean. I sprayed brake fluid and penatrating oil on the valve stems and after working the valve train over and over for about 5 minutes the valves were returning back down when they were suppose to. I was told this motor had very little mileage on this motor and It came out of a 50 mercury car. It sat around in a garage for 6 months. When I bought it the oil was still clean in the motor. I really feel this motor was very recently overhauled. It has a very nice Blue color but I am changing that to Red. The water pump as a small hole on the top side that it shows like it was leaking down the block. Its not the bearing slot hole. It looks like a casing flaw. So I need a good rebuilt water pump . If any one has one or knows where I can purchase one. Please write . and Thank you in advance. RatRoDave
Old 06-25-2007, 12:08 AM
Snowking's Avatar
Snowking
Snowking is offline
FenCo out of winipeg Manitoba sold me one for a 239. I also have a parts catalogue from LMCtruck.com I would imagine could set you up with one. Also BOTP (blue oval truck parts) whom is a sponser of this website I am sure could also set you up with one.
I suggest BOTP because they sell a good product (also maybe this way I won't get in trouble for mentioning the competion)
Sounds good bout the motor, in my 1949 M47 truck the mtor was rebuilt in the Ford accretied plant in Winipeg Manitoba in 1965 then the truck was parked in 1967 (I do know this to be a fact) and somehow 40 years latr the motor was still mainly unseized and recently reved up for the first time by myself.
Once you do get your 226 goin I suggest burning a little 2 stroke oil lubricant in each tank of gas, todays gasoline is dry and your valve train will thank you.
Old 06-25-2007, 12:09 AM
Snowking's Avatar
Snowking
Snowking is offline
Hey RedSkin12B
just wonderin whats the story on your machine????
Old 06-27-2007, 01:20 AM
RedSkin12B's Avatar
RedSkin12B
Well thanks to my Travel agent I haven't had time to look into it...and I really want to have the parts on hand to fix it if it needs fix'n before I tear in to it. But when I get back from my visit to Fort Irwin I'll look into things....
Brad
Old 06-27-2007, 02:16 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
7HA-8501 is the waterpump used on 226 engines for F Series trucks.
7HA-8591 is the waterpump repair kit for the above pump.
You might try joblotauto.com for the pump or kit.
Another source is Hemmings Motor News = hemmings.com.
Old 06-28-2007, 09:14 PM
flat6inline
Thumbs up return to sender
Thank you so much for taking time to respond to my questions.
I will look at the two sites you mentioned tonight.. Dave.
Old 07-16-2007, 01:12 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
Kanter Auto Products lists the Water Pump in there catalog also.
www.kanter.com
Old 08-04-2007, 07:51 PM
RedSkin12B's Avatar
RedSkin12B
Well I took it to a couple of wrench turners I work with and seem to think that the main bearings are bad soo I think I'll try and rebuild the lower half. And see if that fixes it.
Brad
Old 08-04-2007, 08:25 PM
Snowking's Avatar
Snowking
Snowking is offline
Talk about worst case.
Well better to find it now then later.
Good luck and hope you don't decide to do the easy thing and put in a set of valve covers in your truck
Old 08-05-2007, 06:03 PM
fordguy76's Avatar
fordguy76
fordguy76 is offline
I have a 300 6cyl that made a terrible metal sound and looking it was the waterpump pulley it only had three bolts and at idle it sounded something like your engine then at higher revs it balanced out and was quiet, something like what SNOWKING said, might be the ticket.
Boondockdad
05-02-2017 09:24 AM
Farmtruckn
08-18-2015 01:31 PM
1973dieselhighboy
11-23-2011 03:21 PM
GreatNorthWoods
18
10-06-2009 06:07 AM
JBronco
1978 - 1996 Big Bronco
09-28-2001 06:19 AM
Quick Reply: Water Pump on Flat 6
