How To Control TCC Lock Up
#92
Actually it can lock in first too according to Mark K. See here: https://www.ford-trucks.com/forums/1...l#post14667332
So you had a bad PSOM.
#93
It does not lock in "Manual First" under any conditions.
This is stated in the "E4OD Automatic Transmission Reference Manual" in chapter "Theory/Operation" page 8.
I think we are talking about the E4OD transmission in this thread.
#95
#96
OD (overdrive) is fourth gear in the transmission. When you press the button on the end of the shifter and the OD OFF light is on the transmission won't shift to fourth gear. Torque converter lockup can happen in third gear and fourth gear, and in some limited amounts in first and second gears, too.
#97
M
My 91 F-150 stalls when I put the auto trans in gear! Would putting a switch to operate the TC lock possibly help me?
#98
The first thing to do is to check codes. Here's How
Then decide if you want a work around, or want to fix it. Fixing it may be easier than adding a switch.
#99
89 351w, tcc c6....
@55mph The rpm is 2600....should b 1800 or so, also no power on a 10 degree grade...terrible gas mileage!!!!
#100
bigjason_5
20
11-03-2015 04:54 AM
elskeptico
04-21-2012 03:14 PM
quaddriver
20
11-01-2011 02:24 PM
allingeneral
1997-2006 Expedition & Navigator
09-25-2011 04:47 PM
