PLEASE HELP!
Old Apr 30, 2021 | 12:42 PM
JKHinely2606's Avatar
JKHinely2606
PLEASE HELP!
Where is a 1995 Ford F250 transmission control module located? Pretty positive that is what it is, but can't find where it is located. Any ideas on where to find the actual part for sale? As soon as I think I have found it, is says does not fit.
Old Apr 30, 2021 | 02:11 PM
torq'ta 5 8's Avatar
torq'ta 5 8
what trans do you have, and what says module is bad?
Old Apr 30, 2021 | 03:15 PM
Conanski's Avatar
Conanski
If your truck has a computer controlled trans a single PCM controls both engine and trans, it is located in the drivers side kick panel and is accessed from the engine bay by disconnecting the engine wiring harness.
Old Apr 30, 2021 | 03:38 PM
rla2005's Avatar
rla2005
I assume diesel trucks have the PCM in the same location as gas trucks in this era? Seems like 1994 and earlier IDI diesel trucks had a transmission controller mounted near the driver side inner fender.
Old Apr 30, 2021 | 04:15 PM
JKHinely2606
1995 F250 transmission control module location and remedy
4 speed trans. Nothing says it's bad. It's erratic shifting. Delayed shifting response from lower gears while accelerating, random shifting between gears, Slow acceleration.
Old Apr 30, 2021 | 04:55 PM
rla2005's Avatar
rla2005
If it is a gas engine truck run the Key On Engine Off (KOEO) tests and Stored Code display.
If it is a diesel you may need a special code reader?
Old Apr 30, 2021 | 07:36 PM
JKHinely2606
1995, Not a diesel and has a new computer
Old Apr 30, 2021 | 08:04 PM
rla2005's Avatar
rla2005
The engine computer also controls the transmission. Did you run the KOEO tests and Stored Code display before replacing the Powertrain Control Module (PCM)?
Harley Coulter
2015 - 2020 F150
Feb 26, 2021 11:05 PM
Powerstroke2004.5
Oct 6, 2019 11:23 PM
woodnthings
Feb 5, 2011 05:04 PM
edf250
Feb 14, 2010 05:27 PM
