1978 - 1996 Big Bronco
Shifting into reverse
Old 01-18-2000, 04:07 PM
Ltds03's Avatar
Ltds03
Ltds03 is offline
I have a 93 bronco ,,,with the 5.8 and the E40d tranny,,,,when i shift into reverse from park or drive it takes about 3 or 4 seconds to shift into reverse and when it does it hits pretty hard,,,when i come out of reverse into neutral the rpms jump bout 200 and i can feel it shift a little hard as well ,,,,what could this possibly be ,,,any info will be greatly appreciated ,,,thanks
Old 01-21-2000, 08:04 AM
Chuck P.'s Avatar
Chuck P.
Chuck P. is offline
I think the first thing to do is check the fluid level and condition of the fluid, if it's not a nice reddish color and smells burn't, get it out of there. Change the filter and drain the torque converter as well. If it's not this, then I think you may have some real problems like the converter is shot. I believe these are known somewhat to be a weak link in an otherwise great truck-if you don't have an aux. tranny cooler, it may be worth the time and effort to install one. Heat is the number one killer of auto's. Sorry I can't help more than this as I have a C-6 myself. Chuck P.
Old 03-09-2000, 01:26 PM
big60's Avatar
big60
big60 is offline
Old 05-17-2000, 07:13 AM
tapecat's Avatar
tapecat
tapecat is offline
I just went through the same problem with my 94'.The dealer I took it to tried a full on, HI-Tech (high priced)flush. No results, oh and by the way I change the fluids on my truck more often than most people get gas. The next time I brought it in they replaced the throttle positioning switch inside the tran. case. This ment replacing the gasket also (I had a fluid seep there anyway). This did the trick at a cost of, 125 dollars for the flush & Around 300 dollars for the TPS & Gasket
quinttheman
Aerostar
09-09-2012 08:04 PM
mikerans
08-08-2011 09:59 PM
southcoast
06-08-2011 02:03 PM
Insane Wheeler
08-27-2008 06:11 AM
hbonham
06-27-2007 12:13 AM
Quick Reply: Shifting into reverse
