Fluid types and levels....
I'm about to flush my difs, tranny, and transfer case, but there are a couple things I need to know. I was able to find the info about the tranny, but for the difs (f and r) as well as the transfer case, I need to know how much fluid, and what kind. I would consult the owners manual, but never got one. my truck is a 1997 Ranger V6 4.0L 4x4.
Thanks!
Thanks!
Fill the diffs to the bottom of the fill plug so that the oil just starts to spill out. I have no idea how much oil they will take.
As for the transfer case, some are lubricated from the trans, some are not. If it isn't, then there should be a fill plug on it. Fill it to the bottom of the fill hole just like the diffs. Again, I have no idea how much oil it will take.
Originally Posted by howse
I would really like to pop open my owners manual, but I never received one when I bought it. Anyone here able to tell me the proper oil? Thanks for the help.
Pat
Ford Factory Fill Fluids
Check out www.chrysanstore.com for (5) gal. PAILS of a variety of Ford factory fill fluids including:
- Ford (ESP-M2C166-H) Type H ATF
- Ford (WSS-M2C938-A) Mercon LV ATF (new)
The engineering specifications are also posted there.
I hope this helps.
I hope this helps.
Originally Posted by RangerPilot
Tranny: MERCON ATF
Transfer case: MERCON ATF
Diffs: API GL-5 SAE 90 hypoid gear lubricant (if you have limited slip, add four ounces of friction modificer)
4yrhealth
03-29-2017 08:10 AM
travisp_95
10-06-2012 05:11 PM
