Fluid time
Old Dec 22, 2015 | 10:15 AM
Njstern87's Avatar
Njstern87
Fluid time
Hey all,
My early 99 is due for some fluids. Want to change coolant (currently green), service the transmission (automatic), front and rear dif, xfer case and oil. I usualy used delo or valvoline 15/40 for my oil, but am looking for recomendations for all other fluids. Also not sure how much transmission fluid this will hold doing a drain and fill, also planning to drop pan and change filter.
Old Dec 22, 2015 | 10:34 AM
jhl3's Avatar
jhl3
Opinions will vary on almost every question with the exception of coolant. Since it is a e99, you should probably continue to use the old green coolant and add the SCA.
Old Dec 22, 2015 | 10:52 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Amsoil, Rotella, Redline, etc... Oil and fluids are a thing of personal selection.
Personally I use Rotella T6 for engine oil, everything else is Amsoil products.
Old Dec 25, 2015 | 01:24 PM
arto_wa's Avatar
arto_wa
Originally Posted by Njstern87
Hey all,
Here is a link to very good instructions regarding the 4R100 transmission fluid change:
Changing ATF Fluid in a E4OD and 4R100 transmission - Ford-Trucks.com
Old Dec 25, 2015 | 01:50 PM
arto_wa's Avatar
arto_wa
Hey all,
Here is what I am using in my e99:
Engine oil: 15 quarts of Shell Rotella T6 5W-40 (Synthetic)
Rear axle: 5+ quarts of Motorcraft 75W 140 Synthetic Rear Axle Lubricant and Motorcraft friction modifier
Front axle: 3-4 quarts of SAE 75W-90 Gear Oil (will go to synthetic next)
Power Steering: 4 quarts (includes flushing) of Mobil1 Synthetic ATF Oil
Coolant: 33 quarts of Green AF / water mix
Old Dec 27, 2015 | 12:27 PM
arto_wa's Avatar
arto_wa
Thanks for asking!
Old Dec 27, 2015 | 03:22 PM
jhl3's Avatar
jhl3
Not trying to beat a dead horse, but.... if you haven't already..... because it is a e99
You will need to add SCA's Supplemental Coolant Additives on a regular schedule to prevent cavatation.
The below thread which is an excellent compilation of many threads by Stewart H addresses this issue in several places.
https://www.ford-trucks.com/forums/9...formation.html
Old Dec 27, 2015 | 08:18 PM
arto_wa's Avatar
arto_wa
Yes, I forgot to mention adding and testing SCA!
Old Dec 28, 2015 | 08:11 AM
rufushusky's Avatar
rufushusky
Hey all,
Might want to throw brake fluid on this list....
You could run green w/ SCAs or pre-charged coolant like Fleet Charge or Napa fleet. It is usually pink or purple in color.
Old Dec 28, 2015 | 09:39 AM
jhl3's Avatar
jhl3
I have not looked at either of those to make sure that they are totally compatible with the e99 weirdness. Is it possible to add supplemental SCA's to them once the pre-charged SCA's are depleted?
I'll check them out.
Old Dec 28, 2015 | 10:01 AM
rufushusky's Avatar
rufushusky
Yes, think of precharged coolants as conventional green with SCAs already in it. Follow the same procedure with regular testing and top off if needed. They were industry standards until OAT based ELCs showed up. Still used on applications that have sealants or seals that 2-EHA (a component of many OAT based coolants, including Dex-Cool) find yummy.
Old Dec 28, 2015 | 01:50 PM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by Sous
... Oil and fluids are a thing of personal selection...
I will skip coolant since you're SCA and I'm ELC.
Engine oil - Mobil Delvac 1300 Super 15w-40. Southern California doesn't get that cold very often and I've tried most oils (dino and synthetic) and my truck seems to like this the best. I'm currently using Valvoline Premium Blue (it was on sale) and my truck likes it okay but I'll be going back to Delvac once this interval is done.
Transmission, power steering, and transfer case - Mobil 1 Synthetic ATF. If it's good enough for the space shuttle then it's good enough for me. It worked great in my F-150 and has been good for my F-250 for over 8 years.
Front differential - Mobil 1 Synthetic 75w-90
Rear differential - Mobil 1 Synthetic 75w-140
Brake fluid - Valvoline synthetic Dot 4
Grease - Valvoline Synpower full synthetic
Again, this is my personal preference and .02
I've done this several times and have stopped. I can't remember the thread (it was here on FTE) but a transmission shop owner chimed in about flushing transmissions. He said based on his training and other super secret shop owner knowledge that he wouldn't flush the 4R100 with a machine or the driveway procedure linked above. Again, I don't remember the specifics of the thread other than it was compelling and now I only drain the pan and add the 7 or so quarts to top it back off every 30K. The original owner (I'm the second) had the transmission rebuilt at 120K by the dealership. I've got 165K on this transmission so far and it's still going strong.
Old Dec 28, 2015 | 02:51 PM
arto_wa's Avatar
arto_wa
Nothing wrong with what you called "the driveway procedure".
I agree with what you said about not flushing with a machine at a quick lube shop though!
Old Dec 28, 2015 | 04:16 PM
tonym17's Avatar
tonym17
shell for the oil....amsoil in everything else....I even use amsoil grease...
Old Dec 28, 2015 | 05:21 PM
Stewart_H's Avatar
Stewart_H
Actually it's a compilation of a couple threads by Gooch, along with info picked from Gooches brain by me, a lot of my own research (that can be fact checked by anyone who knows how to use the 'net) and input by our outstanding membership.
Exactly this.
...that have sealants or seals that 2-EHA (a component of many OAT based coolants, including Dex-Cool) find yummy.
That right there is a sig worthy quote.
The machines at the quick lube shops are the same as the driveway method, just with a machine instead of a bucket.
What a person has to be concerned with at a place that will flush the trans fluid is to make sure they don't use a chemical flushing agent that may or may not play well with the trans guts. If they ONLY introduce and replace trans fluid as the old trans fluid is removed, then you're good to go.
Just make sure they use Mercon V.
Stewart
