Passenger Fuse Panel Layout?
Old 05-01-2007, 12:33 PM
anttho's Avatar
anttho
anttho is offline
Question Passenger Fuse Panel Layout?
Anyone have a layout of what fuse is what? I am looking for the layout under the steering wheel fuse compartment. Reason is the power outlet next to the trash bag holder on the front dash stopped working... tried to pull a bunch of fuses but don't know which one it is. Also the driver heated seat option stopped working-the light on the seat control lights up but no heat on the seat.. Thanks all
Old 05-01-2007, 12:46 PM
fatswany's Avatar
fatswany
fatswany is offline
Owners manual has both layouts, at least in my 2000......could be the panel under the hood.
Old 05-01-2007, 01:03 PM
anttho's Avatar
anttho
anttho is offline
don't have the owners manual looking to see if there is anything online? that i can look at.
Old 05-01-2007, 02:12 PM
VaSheriff's Avatar
VaSheriff
VaSheriff is offline
Go here and download your manual. It's in the manual of course.
http://www.fleet.ford.com/maintenanc...ls/default.asp
Old 05-02-2007, 07:34 AM
anttho's Avatar
anttho
anttho is offline
Smile
thanks for the help.. It was in the 2000 manual.. the 2001 manual for some reason does not have the fuse panel info..
Old 05-02-2007, 08:54 AM
fatswany's Avatar
fatswany
fatswany is offline
That bites, guess you need to get a Haynes or Chilton manual. Good to have anyway, wouldn't be without one, have them for all six vehicles.
Did the 2000 manual layout match what you have?
Old 05-02-2007, 09:12 AM
anttho's Avatar
anttho
anttho is offline
yep almost exactly the same...got the power port working now just need to figure out the driver heated seat. the passenger side works so i switched the module under the seat with that one but still no heat.. Have a fealing a fuseable link or something inside the seat where i can't go, is wrong with it.
Old 05-02-2007, 01:23 PM
njstevens's Avatar
njstevens
njstevens is offline
Heated seats in Ford and Lincolns are notoriuos for going out and expensive to replace. A warm truck runs better anyway on cold days so just warm it prior to leaving.
laxdad
1999 to 2016 Super Duty
09-18-2015 10:59 AM
wrd0225
05-23-2012 04:57 AM
victorcharlie
Electrical Systems/Wiring
11-10-2003 10:53 PM
clncrpt
1997 - 2003 F150
03-19-2003 04:57 PM
sdsurf
03-19-2002 03:46 PM
Quick Reply: Passenger Fuse Panel Layout?
