y-block, strange high pitched whine
292 f-100 3 on tree. Got this high pitched whine. Already eliminated the alt, and water pump as a source. Also checked the dist. Sound seems to be comming from the back of the engine. This is my daily driver and she still runs and drives ok,, but this sound started about 3 weeks ago and its driving me crazy. Any ideas?
Does it sound the same with the clutch dis-engaged, the trans in gear, and the vehicle not moving? Does the sound change character or loudness with increases of engine rpm?
Even if the sound is "metallic", you could have a vacuum leak whistle. Use a hardwood stick about two feet long to transmit the sound from the source to your ear. I press one end of the stick against a suspect component (generator) and the other end against my skull behind my ear. Another improvised stethescope is to use a two-foot length of hose - it will be better for looking for whistles.
