Bronco II Ford Bronco II
putting on a fender
Old 04-16-2007, 10:34 PM
billyco's Avatar
billyco
billyco is offline
putting on a fender
i need to put a passenger fender on my b2 is this a hard job and do i have to remove the front bumper
Old 04-17-2007, 03:29 AM
Help I M Stuck's Avatar
Help I M Stuck
Help I M Stuck is offline
front bumper can stay on.
Old 04-17-2007, 06:20 AM
kernel-panic's Avatar
kernel-panic
kernel-panic is offline
Not a difficult task, and you can do it with the bumper in place, but it makes it easier if the bumper is removed. You have several bolts to remove, as well as removing the side running light lens assembly and all the screws for the inner fender. Two of the bolts (8mm head, IIRC) are at the rear of the fender, one top, one bottom. I forget the number of bolts, but you have several under the hood along the top of the fender, two for the front fascia, and two to four for the radiator core support. It's been a while since I've yanked one of these fenders and replaced 'em, but that should be about it. Hope this helps.
Old 04-17-2007, 06:30 AM
billyco's Avatar
billyco
billyco is offline
thanks i got to get on this and get it done
Old 04-19-2007, 04:11 PM
billyco's Avatar
billyco
billyco is offline
i got the fender on thanks for the imfo
Hammer40330
1999 to 2016 Super Duty
07-14-2016 11:27 PM
Marten
19
02-16-2016 07:41 PM
zoomeroo
06-26-2013 12:40 AM
SuperDad
12-30-2012 09:55 AM
kengarchow
20
08-04-2009 07:24 AM
Quick Reply: putting on a fender
