4.6L F150 or 5.4L F150?
Old 10-15-2002, 12:04 AM
AlwaysStuck's Avatar
AlwaysStuck
AlwaysStuck is offline
Whats better? 5.4L with 115 000 Mi on it or 4.6 with 95 000Mi on it?
Old 10-15-2002, 08:22 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Run a compression test on it and hook up an oil guage. Those two test will tell you more about the condition of an engine than anything else. Easy tests, anyone can do it with about a $30 investment and it takes 5 minutes. :-)
Old 10-15-2002, 09:21 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
5 minutes to either do a compression test or hook up an oil pressure gauge in a newer F150? This I want to see
Old 10-15-2002, 04:04 PM
Squiggy's Avatar
Squiggy
Squiggy is offline
ME TOO
Old 10-22-2002, 02:45 AM
chevrolet's Avatar
chevrolet
chevrolet is offline
If you were experienced at it, and you didn't do all the cylinders, you could do it. but for the average person, No way. Not even just doing a couple of cylinders. It would probably take most people loner than 10 minutes just to locate the oil tap, and install the gauge.
Old 10-29-2002, 10:08 PM
tgenetzky's Avatar
tgenetzky
tgenetzky is offline
The silverado is a car, not a truck.
Old 10-30-2002, 08:39 PM
geoaigel's Avatar
geoaigel
geoaigel is offline
That question is quite vague? What is better? What are you looking for?
Both engines are very good engine. The 5.4 is somewhat more old fashioned and there is no replacement for displacement, as we know.
However, the 4.6l is a more modern enigne with overhead cams and can make a great work horse, especially in a truck that doesn't see a trailer behind it most the time.
I would rather have the low mileage engine for longlivety reasons. Wife's truck has the 4.6l with 155k miles and it runs great!
I also wanted to add that compression tests on the 4.6l are practiaclly impossible unless you get the truck for a whole day. Changing spark plugs took me 1.5 hours *with* the correct tools borrowed from a mechanic friend.
Cheers, George
Old 10-30-2002, 11:39 PM
ToddnMiss's Avatar
ToddnMiss
ToddnMiss is offline
teslaphysics
1997 - 2003 F150
01-25-2015 11:48 AM
vini888
2009 - 2014 F150
02-05-2011 01:35 PM
FordF350Baby
Oil & Lubrication
24
08-06-2008 04:41 PM
gmbpilot757
1997 - 2003 F150
10-31-2002 08:09 PM
Yellardawg
1997 - 2003 F150
03-19-2002 04:36 PM
Quick Reply: 4.6L F150 or 5.4L F150?
