69 Transmission
69 Transmission
My son has a 69 F250 (Camper special 2 wheel) with a rebuilt 390...he took it to the shop for some rewireing. Got it home and now the tranny won't shift into third. It hardly does any shifting now...ideas? Not real familiar with this tranny, any ideas on which tranny it could be as well, maybe I can find another at a local yard.. shold be too hard to replace.. he did replace the neutral safety switch as well
There should be vacuum hose or tubing that runs from the vacuum modulator to the intake manifold. If the modulator doesn't get a vacuum signal, the transmission will shift late - way after it should. It's possible the vacuum hose or tubing was knocked loose during the work being done. The modulator valve is mounted on the transmission at the passenger side rear, just above the pan.
f150country
12-01-2016 10:53 PM
Nate414
11-11-2011 10:59 AM
rknight29
64
11-03-2011 03:34 PM
