1979 Bronco 460 swap motor mount question
Old 04-15-2007, 06:17 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
therfore, I can assume the reason the OEM set-up not going to work on a 4wd truck is because of the lack of the front crossmember...this , I guess leaves us back with the original choices of:
1. L&l---lot's of problems reported with the mounts breaking but very easy to install.
2. Performance unlimited...supposidly much better but have to modify the existing tower, no biggie for a torch and grinder.
3. North Country which I do not know much about except that they cost $225.oo a pair but supposidly will solve fan shroud line up issues.
Ball's in your court guys...anything I've missed?
  #32
Old 04-15-2007, 06:18 PM
buzzbait65's Avatar
buzzbait65
buzzbait65 is offline
Originally Posted by Mil1ion
What site did you find that at ?
http://73-79fordtrucks.com/
  #33
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
I changed it myself at www.spellcheck.com
I know YOU aren't yelling...I mean it as perceived by many.
The OP made a thread at project bronco where they have a tech article on this swap
  #34
Old 04-15-2007, 06:19 PM
buzzbait65's Avatar
buzzbait65
you have the L&L mounts now, if they break, change them later
  #35
Old 04-15-2007, 06:20 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
80's mounts
  #36
Old 04-16-2007, 10:23 AM
lisagoud's Avatar
lisagoud
lisagoud is offline
well, from what I can tell North Country Specilaities seem to be the way rto go from all those that have used them.
  #37
Old 04-16-2007, 04:40 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
armstrongfordtrucks is offline
lisagoud
I am replacing my 390 with a 460 presently and used direct bolt up mounts from Summit Racing, around $60.00 and they worked great, using the rubber mounts from a 4X2 truck. You can see pic's in my gallery, need more E-Mail me. cpbrady@zoominternet.net
Have a great day
  #38
Old 04-16-2007, 04:54 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
thanks, email sent!!!
  #39
Old 04-16-2007, 05:29 PM
lisagoud's Avatar
lisagoud
lisagoud is offline
now I came up with some oither options...anyone have any experieince in these?
SearchMake & Model
by Engine
Order Status
Wishlist
Free Catalog
Brand
Hooker Headers
Trans-Dapt Performance Products
Product Line
Hooker Super Competition Engine Swap Mount Kits
Trans-Dapt Performance Motor Mounts
Part #
HOK-12677HKR
TRD-9433
Description
Motor Mounts, Engine Swap, Steel, Black, Ford, Bronco/ F-Series Pickup, 429/ 460, 4WD, Kit
Bracket Finish
Black painted
Black painted
Bracket Included
Yes
Yes
Bushing Color
Black
Black
Bushing Material
Steel
Steel
Motor Mount Style
Complete mount
Complete mount
Notes
Use factory stock rear transmission mount.
Other Ford parts are necessary to complete the installation.
Quantity
Sold as a kit.
Sold as a kit.
Transmission Mount Included
No
No
  #40
Old 04-16-2007, 07:37 PM
mark a.'s Avatar
mark a.
mark a. is offline
L&L's do have a lifetime warrenty. So who cares if they were to break once in a while ? But I doubt they ever will unless you have some big stroker motor.
  #41
Old 04-16-2007, 07:52 PM
79superduty's Avatar
79superduty
79superduty is offline
If you dont mind a solid motor mount you can take the 460 engine side and and cut off the rubber and then take 351 0r 400 frame side and cut off the rubber and bolt the 460 side to the motor and the m side to the frame.. lower the motor in and tack the two mounts. there should only be about 3/4 of an inch between the twoand remove and weld solid .you should 3sides on the mount to weld good luck.
B00M3R
17
01-25-2016 10:44 AM
flowney
07-14-2014 03:08 PM
jarod17
Testing.....
06-28-2011 10:57 PM
leotismumford69
22
12-08-2008 07:35 PM
Quick Reply: 1979 Bronco 460 swap motor mount question
