HELP!!! Rear end feels way too tight!
Hello! I just bought a 2000 F150 ext. cab short bed 4x4. Its got the 5.4 engine and 3.55 LS rear end. Anyway, the tires chirp and "grind" around the corners as if the axles are locked together. The rear end isn't leaking any fluid. The truck has 100,000 miles on the clock. The differential doesn't make any vibration and seems to be great except when taking tight turns. It feels like the axles are locked together, and I am sure the rear end has never even been opened so everything should be factory. It feels like its got a detroit locker in the back. What would cause the limited slip to lock up like this?
Would it help if I changed the rear end fluid and put some limited slip clutch additive stuff in there?
Has anybody else ever had this problem?
I just don't want to hurt my limited slip clutches or tires because of this.
I had the same problem after my stealership replaced the fluid....they originally added 4oz of the friction modifier and it still did it...they added a total of 8oz and it solved the problem.
if it ever stops snowing here, i'll be changing again, to Amsoil and adding their FM even though they claim you don't need it.
drj
i know that ford does not make a locker - but it IS a used vehicle with high miles - so it IS possible that someone had a locker installed and you would never know without opening it up. he did say that he just bought it. so before we all decide theres something wrong with his truck...you have to consider other options.
i only suggested that - because i have a detroit in the rear and the symptoms are IDENTICAL.
drj
drj
UPDATE:
I opened the rear-end (which has never been opened before BTW). Everything looks good inside. The fluid was brown and foamy. It didn't look like water had ever been in it or anything. I replaced the fluid with Mobil One Pure synthetic 75W140 and a 7 ounce tube of Ford Friction modifier, but I am still having the same issue. I tried doing a bunch of tight figure 8s to get the fluid around in the clutches. Will it take a few miles for the change to happen?
Any other advice?
Any other advice?
UPDATE:
Any other advice?
Any other advice?
wildstang
1999 to 2016 Super Duty
04-27-2010 12:22 PM
mcne
09-22-2005 07:40 AM
