Convert 2WD trans to 4WD (auto)
One of the users here named Arctic Y Block said in another thread he has converted several C6s and the trans does not need to be completely disassembled. IIRC he says you pull the trans, remove the valve body, stand it on the bellhousing end, remove the tail shaft housing, remove a snap-ring that holds the tail shaft in and carefully slide it out so as not to disturb the internals. Then you reverse the process using the "new" parts. If you go the C6 route maybe you could pm him and get more info.
Bramoutar2
06-21-2017 11:32 PM
88blackgt
07-11-2009 01:30 AM
