Wind Noise
#31
I drove my gfs 2005 Toyota Corolla and man that car is noisy. Almost no noise proofing. You can hear the tires, cars go by, etc. The ambient noise level is much greater than the Expedition. Maybe that's why I can hear the noise from the mirrors. If that wasn't there the cabin would be insanely quiet.
#32
Originally Posted by AmericaRocks
berry1234,
What type of brake work did you have to have done?
My dealer has two mirrors and a driver side weatherstripping on order for my 07 Expy EL for the wind noise issue.
Just recently, I have noticed a bad brake squeal. It happens as I am stopping right before I come to a complete stop. I am going to have them look at it when I take it in.
Thanks.
Thanks.
Unfortunately, they were unable to reproduce the brake noise issue. My brakes are still squealing intermittently. I'm trying to determine the pattern (hot, cold, whatever, so I can reproduce for them). It’s not that bad, but something doesn’t appear to be right.<O</O
#33
Just a quick BUMP to anyone with an '07 that hasn't had their exterior mirrors replaced under the TSB.
I have always had some wind noise, but never considered it too bad. I had the Expy at the dealer for a rear seat rattle (replaced the seat frame) and a trim piece that was falling off (above the tailgate) and asked my service rep to perform the TSB for mirror replacement. She didn't even blink.
It took about a week for the mirrors to come in and then two days for them to be painted (I have a Limited). I just drove the truck home from the dealer and the difference is PRONOUNCED. The truck's interior noise level has dropped by at least 1/3. I had no idea how bad it was. I really can't see a difference in the mirrors themselves, but they clearly have fixed something about the design or production.
As a side note, the redesigned Escape that they gave me as a loaner last night is actually pretty nice. I was impressed.
Just thought I would pass this on - I suggest anyone with an affected 07 mention the TSB the next time they are in service.
#34
Problem is even with the new mirrors, they still make a wind rush sound, especially driving into the wind. My Expy did not need new mirror, but the dealer replaced them and the outer weatherstripping to help the A pillar/mirror wind rush sound. When the wind is at your back I can hardly hear a thing. Funny how they market wind tunnel test to reduce wind noise. My older Expys were much quieter than my 07.
#35
Just got my 2007 Eddie Bauer EL back after having to leave it with the dealer for three days. I brought it in for routine maintenance and mentioned the wind noise problem I have. I also had a copy of the two TSB's with me which I handed to the service advisor. He thanked me for having them and attached them to the repair order. Well three days later I have two new mirrors and two new glass window runs and the best part is NO MORE WIND NOISE -- the cabin is super quiet. What a difference. These new mirrors are designed much better than the ones I had (my EL had a production date of 9/06).
Thanks to all for posting the issue and the TSB's.
#37
There are two... here is a link to the first (suggests replacing glass runs)
https://www.ford-trucks.com/lc/lc.ph...wtopic%3D13655
The second one (which suggests replacing the mirrors) I don't have a link to, but here is the text. I hope this helps.
<TABLE><TBODY><TR><TD vAlign=top width="100%">FORD: 2007 Expedition
LINCOLN: 2007 Navigator
ISSUE:
Some 2007 Expedition and Navigator vehicles built before 05/07/2007 may exhibit wind noise around the exterior driver and/or passenger doors. This may be most noticeable near the A-pillar area of the door.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE: IF THE VEHICLE BUILD DATE IS ON OR AFTER 5/07/2007, THIS TSB DOES NOT APPLY. CONTINUE WITH NORMAL WORKSHOP MANUAL DIAGNOSTICS.
Tape the trailing edge of the mirror sail down to the front window glass from the tip of the mirror sail to the belt molding.
If the noise goes away, replace the mirror on the effected side. Both mirrors do not have to be replaced.
If the noise does not go away, continue with normal Workshop Manual (WSM), Section 100-04 diagnostics.
PART NUMBER PART NAME
8L1Z-17682-AA Mirror - Expedition-Passenger - Power/Heated Convex - Middle Eastern Countries
8L1Z-17682-BA Mirror - Expedition-Passenger - Power Heat/Memory
8L1Z-17682-CA Mirror - Expedition-Passenger - Power Heat/Memory - Middle Eastern Countries
8L1Z-17682-DA Mirror - Expedition-Passenger - Power/Heated Convex
7L1Z-17682-EA Mirror - Expedition-Passenger - Power
7L1Z-17682-FA Mirror - Expedition-Passenger - Power - Middle Eastern Countries
8L1Z-17682-GA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold / Expedition-Power Fold, Power Adjust
8L1Z-17682-HA Mirror - Expedition-Passenger - Power Fold/Power Adjust - Middle Eastern Countries
8L7Z-17682-AA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold
8L7Z-17682-BA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold - Middle Eastern Countries
8L1Z-17683-AA Mirror - Expedition-Driver - Power/Heated
8L1Z-17683-BA Mirror - Expedition-Driver - Power/Memory/Heat
7L1Z-17683-CA Mirror - Expedition-Passenger - Power Heat/Memory - Middle Eastern Countries
8L1Z-17683-DA Mirror - Navigator-Drivers - Power Heat/Memory/Power Fold / Expedition-Power Fold/Power Adjust
8L7Z-17683-AA Mirror - Navigator-Drivers - Side Power Heat/Memory/Power Fold
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071615A 2007 Expedition/Navigator: Replace One Mirror, Includes Time To Road Test To Verify Concern (Do Not Use With 17682C, 23943A) 0.7 Hr.
071615B 2007 Expedition/Navigator: Replace Both Mirrors, Includes Time To Road Test To Verify Concern (Do Not Use With 17682C, 23943A) 1.1 Hrs.
071615C 2007 Expedition/Navigator: Extra Time To Paint One Mirror, This Labor Operation Should Be Claimed With Labor Operation A (Do Not Use With P101, P17) 1.0 Hr.
071615D 2007 Expedition/Navigator: Extra Time To Paint Both Mirror, This Labor Operation Should Be Claimed With Labor Operation B (Do Not Use With P101, P17) 1.5 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
17682 07
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2007 Ford Motor Company
</TD><TD vAlign=top align=right width=300>
</TD></TR></TBODY></TABLE>
__________________
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
17682 07
__________________
psycoreefer
06-01-2015 06:39 PM
