Methanol Recovery (Vaccum)
Old 03-30-2007, 09:11 PM
blieux1's Avatar
blieux1
blieux1 is offline
I need some help on making a vaccum recovery system . Some pictures or plans would be helpful. I have everything to build it but need to know exactly what i'm doing.
Old 03-31-2007, 08:56 AM
Pele's Avatar
Pele
Pele is offline
Read up a little on Stills.
You want to build the condensor part of a still.
http://www.moonshine-still.com/page2.htm
Ethanol and Methanol are both alcohols, so this should work out.
You need a vessel to contain your diesel, a vacuum pump, and this condensor...
Fill your vessel, attach the input of the vacuum pump to the vessel and apply heat to your vessel. Attach the condensor to the output of the vacuum pump, and the condensor should produce methanol.
The vacuum pump reduces the heat necessary to boil out the methanol as the high altitude makes boiling water take less heat.
Where did you get your vacuum pump?
Old 03-31-2007, 10:30 AM
blieux1's Avatar
blieux1
blieux1 is offline
Got it from work, its an industrial pump that was on an oil recovery system.
Truck Guy99
11-06-2013 12:34 PM
OTTOMATIC
05-15-2010 10:13 PM
drtire
1999 to 2016 Super Duty
03-22-2008 08:43 AM
pitbulls20
01-05-2008 11:15 PM
MBBFord
Offroad & 4x4
20
07-23-2005 09:54 AM
Quick Reply: Methanol Recovery (Vaccum)
