Need fix for bed holes
The PO of my '73 F100 had installed some tie-down thingies in the bed floor. I took 'em out and I'm wondering what would be the best way to fill these holes prior to painting. The drilled holes are about 3/8" dia. Don't have a welder. Best I've come up with is a piece of metalic tape on the underneath side and fill with something like JB Weld from the top and grind flat. Any ideas? Thanks
No welding . . .
How about screwing on patch squares of sheet steel from the bottom using small (#6) self-drilling, self-tapping screws. Grind off the screw ends flush with the bed surface. Then fill the holes with epoxy (JB Weld) and grind/sand flush. This should be a stable surface for your paint and should handle most rough treatment. Seal up the bottom surface with paint/undercoat.
Originally Posted by acheda
No welding . .
Originally Posted by Keepin It Real
I'm wanting to keep the bed surface smooth. I guess I don't get the bolt/washers/nut treatment. Why use a square bolt in a round hole? And then the washers would be on top with a nut on top of 'em? I have a feeling I'm missing something here. Thanks for you guys' response.
kaw500h1
28
01-07-2017 02:33 PM
low54
13
10-09-2008 05:40 PM
