51 f1 metal front fenders needed
I have a 1951 f1 that I am about to start rebuilding. I need to replace the front fenders. All i can find on the internet is fiberglass fenders. If i can help it i dont want to put fiberglass on my truck. any help will be appreciated.
________________________________-
1951 f1 needs rebuild
1988 f150 4x4
2005 f150
countless parts trucks
1988 f150 4x4
2005 f150
No one makes reproduction metal fenders for these truck. At one time there were some metal bottom halves being made but I don't know if they are still being reproduce. Last time I checked Sacramento Ford had them listed.
Metal fenders are getting very hard to find and if yours are in anyway able to be repaired you may have to repair them or go with fiberglass. Metal fenders do show up on eBay every so often but usually go for big $$$, plus more $$$ to ship such a big item. Swapmeet season is starting so go to as many swapmeet and car shows as you can, you may get lucky and find a decent pair.
Good luck
Good luck
I have an extra set of 51/52 F1 fenders, both uppers and lowers. NO rust through at the bottom. Fenders are original and steel. Fenders are mostly straight (nothing that can't be easily fixed). The only issue is that the right upper fender has a nickel to quarter size rust through hole at the corner where it curves into the headlight area.
As Bob was saying, good fenders demand high $$, especially 51/52 fenders as there were less of them made. I've sold worse 51/52 fenders, with the bottoms entirely rusted out for over $500 a pair.
PM if your seriously interested. I can also have the body work done on them and put in primer. All you'd have to do is paint them and put them on your truck.
Ilya
Ilya
