Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 03-19-2007, 06:04 PM
Jocaren's Avatar
Jocaren Jocaren is offline
Garage is empty, add now
Jocaren is starting off with a positive reputation.
Proven Tranny!
What is the #1 transmission hands down for the 6.0. I want a tranny thats going to hold at least 600 rwhp with no problem!Want t to last for rest of trucks life! I do not drag my truck often, i do haul heavy trailors and get on it a few times a day!
__________________
06 250 4x4 CC,SCT.gauges.studs.exhaust
35x12.50x18 Toyo M/T
  #2 (permalink)
Old 03-20-2007, 11:24 PM
89300L64x4's Avatar
89300L64x4 89300L64x4 is offline
89300L64x4 is starting off with a positive reputation.
in my opinoin its a 6sp manual with a pulling clutch
__________________
95 F250 std cab long bed XLT 7.3 PSD 5sp 4x4 with D60 swap 4.10 gears 140k
89 F150 std cab long bed XLT Lariat 300L6 EFI 5sp 4x4 factory quad shocks 3.55 gears 180k
83 Ranger std cab long bed 351W Fmx auto 2wd
87 F250 std cab long bed Custom 6.9 idi 4sp 4x4 4.10 gears 190k
  #3 (permalink)
Old 03-21-2007, 12:20 PM
lukecline lukecline is offline
lukecline is starting off with a positive reputation.
he's got an auto, i doubt that he's wanting to swap a 6spd into a brand new truck.
Ive heard alot of good things about suncoast transmissions. Also BTS would be one to look at, but im not sure if they do anything for the torque shifts yet.
__________________
99 cc f250 4x4-wildman tuning, wop twins, di ic, richter trans, casserly fuel
96 cc f250 4x4 -38r turbo, stage 1's, TW tuning, elec fuel system, stage 1 trans, intercooler- formerly 12.52 @ 110 mph
  #4 (permalink)
Old 03-21-2007, 11:38 PM
89300L64x4's Avatar
oh ok, well id never heard any bad aftermarket trannys out there so if it was me id go with ats tranny
__________________
  #5 (permalink)
Old 05-28-2008, 05:15 PM
Welk49 Welk49 is offline
Welk49 is starting off with a positive reputation.
Ask Brian at BTS if he doesn't work on them, then call SunCoast or John Wood.
__________________
96 F350 Dom 66 Turbo, TW 6 Pos Chip, Intake, 5 In exhaust, downpipe 4in lift 35's on 18" Eagle Alloys, Intercooler, Beans Stage 2 injectors, Built Auto w/ Billet Triple Disc Conv. and Output Shaft Electric Fuel, 17* HPOP, 5" Stacks.
  #6 (permalink)
Old 07-07-2008, 09:20 AM
bigtorque bigtorque is offline
bigtorque is starting off with a positive reputation.
stay far, far away from ATS........
their customer service is horrible, and ther 5R110 tranny is junk in my experience.
My buddy is on his second ATS in a 450 hp 6.0
__________________
03 F-250 7.3 PSD/CC/SB/4X4--
THANKS TO ---- RAGIN DIESEL - ITP DIESEL - HANSONS TRANSMISSIONS - AMSOIL PERFORMANCE PRODUCTS AND THE BEST IDEAS FROM GREAT FOLKS AT FTE.
  #7 (permalink)
Old 07-07-2008, 12:17 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 is gaining momentum as a positive member of FTE.Pkupman82 is gaining momentum as a positive member of FTE.
Probably won't fit your 6.0 but IMO it's definately the C6 that would be the toughest slushbox out there.
__________________
1977 Ford F250 XLT Ranger 4wd/ 351m/ NP435/ 205
1979 Ford Bronco XLT Ranger/ 460/ C6/ 205
1984 Ford F250 XL 4wd/ 6.9 IDI/ C6/ BW1345
1984 Ford F150 4wd/ 300/ NP435/ 208
1996 Ford F150 XLT 4wd/ 300/ ZF5/ BW1356
  #8 (permalink)
Old 07-07-2008, 12:55 PM
BowTieHatr BowTieHatr is offline
BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.BowTieHatr has a very good reputation on FTE.
Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL
call them. i have heard some good things about them.
__________________
To whom it may concern;
Ford Senior Master Tech since '05
ASE Master Tech '04
6.0ing since '03.
6.4ing IF they tear up
  #9 (permalink)
Old 07-09-2008, 11:46 PM
halerazor halerazor is offline
halerazor is starting off with a positive reputation.
ats builds the best tranny's i've seen. brians truck shop is suppose to be good too. the tranny i saw on his(bts) site had a purple torque converter(ats). the best rule of thumb is find one of the good tranny builders and see which one is closest to you and go with them. autos seem to need some adjustment sometimes no matter who built it.
  #10 (permalink)
Old 07-21-2008, 05:22 PM
Pocket's Avatar
Pocket Pocket is offline
Pocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud of
Read their warranty in detail and you'll find that they don't build the best transmissions. Also read the forums, you'll find they don't have the best reputation either. Trans problems, customer service problems, etc.
That purple torque converter you saw is a Precision Industries Stallion converter, not an ATS. The Stallion converter is bigger and stronger than the ATS one. The reason for the purple paint job is that it is a special paint that turns color when the torque converter is overheated. Quite a few companies use that paint, not just ATS.
???? Mine has never needed an adjustment.
To the OP.... I know this thread was started over a year ago, but since that time Brian at BTS has now built a handful of 5r110's. There's a guy here in the Denver area running one with his 6.0L. I'm not sure if Brian is only building a select few, or if this is available to everyone. Might want to call and ask.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
  #11 (permalink)
Old 08-22-2008, 10:52 PM
william_04_x's Avatar
william_04_x william_04_x is offline
Interstate Menace
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Quote:
Cool info...Rep for you...
__________________
04 EB X w/ 03 6.0l PSD Tunes by Eric at Innovative, ARPs, ITP RR, 4" SS MBRP, Custom Dual HFCMs, ZEX N2O w/custom progressive controls, DC Power Polished 190, Riffraff IC Boots in Red, DieselSite Coolant Filter, DiPricol Boost EGT Fuel Pressure Trans Temp, Michelin LTX MS2, Toyo Proxies, M&H Racemasters, Hellwig, Bilsteins, Firestone Ride Rites, ViAir 480C compressor/3 gal tank, Siege horns, SEIC/High Idle Mod, V1 w/custom LEDs, 55wt 5K HL's, 35wt 5K FL, KC 121 130wt DL's, Clarion NX702, Alpine Amps and Subs.
  #12 (permalink)
Old 08-25-2008, 08:31 PM
Bts
John Wood
Hughes
Sun Coast
Ats
In That Order, From The Best On Down.
__________________
Tags
2wd, 351w, 5r110, 60, ats, brians, converter, manual, precision, ranger, shop, stallion, torque, tranny, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
