1980 identification, not matching
okay how about some help, i got the vin off the dash, sorry didint think the door would have been diff so i didnt get it , i'll go out sometime and double check. according to lmc my engine letter didi not exist in 1980,also the common weights i have seen was 8800lbs for gvwr, again no dice. so here we are ....
vinf26gcgk0348
gvwr, 8000lbs, broke down frt 4500, rr 5300
the rest of the door tag
wheelbase; 133
f262
body dd4
trans k
axle c7
anyone willing to take a shot at this, supposedly it was told to me upon purchase, 3/4 ton with 1 ton suspension, 351m, c6, xlt, red on red
looking for help, really appreciate it, thanks, Dan
vinf26gcgk0348
wheelbase; 133
f262
body dd4
trans k
axle c7
Bacially your truck is like a very late 79.
you can decode the codes here yourself on my page here.
or I can .....if you can't figure them out.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Trans K - new code in 79+ for C6
mil1ion thanks for the help ,i have seen your post for that before, i appreciate the help. it does appear to leave a few unanswered questions. my engine code is a g but it looks wider than a windsor based motor. i'm reasonably certain that it is an M. doesnt mean it wasnt swapped out. then the f262 leaves a big question, doesnt come up on 78-9. an f263 was the lowest number which was a 6?00lb gvw, yet my axle code denotes a -60ls w3.54's rated at 5300lb. any other ideas or another directuion you can point me? thanks again, Dan
vinf26gcgk0348
wheelbase; 133
f262
body dd4
trans k
axle c7
vinf26gcgk0348
wheelbase; 133
f262
body dd4
trans k
axle c7
F26 = F250 4X4
G = 351 2V
C = Ontario Truck
GK0348 = 1980
DD = RED All Vinyl
4 = Pickup 8' Box
F262 = 1980 Pickup F250 4X4
K = C6
C7 = Dana 60 / 3.54-1 / 5300 lb axle capacity~limited slip
bill thanks i could not remember your screen name otherwise i would have just pm'ed you. either way i was reasonably certain you and mil1ion would have something. as for that axle did it come up as a limited slip in your archives? as for the trim it is a bright red ext. and red interior, has a seatcover on it and have not pulled it back to see if cloth or not. so it appears that i bought the truck i thought i bought. and the sticker in the window from the ontario truck plant was pretty obvious. thanks again bill! Dan
VIN Decoded from the: 1980/89 Ford Light Truck Parts Catalog / General Information Section
thanks a million gentleman, i really appreciate it. i knew you two could come up with what i needed. i feel 10 times better knowing i have the right truck, and it matches what it was advertised as. now i can rebuild her, restore her, and enjoy her, while i drive that beater 88. thank you. Dan
Originally Posted by Mil1ion
There were carry over codes for the 80 from the 79
In the DD4
D as Knit and Vinyl bench seat
(the first character of the 3 being the seat type.... for a Bronco, D was a Bucket seat)
D is Red interior
In the DD4
D is Red interior
It'll be interesting to see what interior DusterDan has. The codes are thus:
CD = Red Cloth & Vinyl
DD = Red All Vinyl
FD = Red Cloth & Vinyl
80duallyf350
15
02-28-2015 09:26 PM
cds
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
18
05-28-2009 09:44 PM
Steve_Uzi
1978 - 1996 Big Bronco
02-15-2006 12:39 AM
