Collection Systems
Old 03-09-2007, 10:12 PM
FLASH 13's Avatar
FLASH 13
FLASH 13 is offline
Collection Systems
Can you guys post pictures of how you set up the plumbing for oil collection. i have a 195 gallon tank with one bung and a water/trash pump 2" how do you guys keep ypur trucks clean? i want to set up basically a closed system were the oil flows in/out of the same hose so i can keep things clean....
Old 03-12-2007, 08:56 PM
Murphy2000's Avatar
Murphy2000
Murphy2000 is offline
I use a super sucker.. Like a giant wet-dry vac on steroids.
Pull down 20" of vacuum and open a valve. You can suck peanut butter.. just pressurize the tank to reverse flow.
Gotta have a pressure tank to do this.
Old 03-13-2007, 12:16 AM
kennedyford's Avatar
kennedyford
kennedyford is offline
Flash what kind of means to equipment do you have? Small generator, stuff like that.
Old 03-13-2007, 11:04 PM
FLASH 13's Avatar
FLASH 13
FLASH 13 is offline
I got a huge tank and a 5 hp 2" trash pump....
Old 03-13-2007, 11:09 PM
kennedyford
My totes have a forklift metal pallet under them. I just use a hose and fill from the top. Get home and unload with a forklift. Any plumbing you can think of will work.
Old 03-14-2007, 10:20 AM
Gun-Driver's Avatar
Gun-Driver
Gun-Driver is offline
I pretty much have the same set up except I use 55gal plastic drums to pump into.( easier to take in and out of the truck by myself) I use a 2" gas pump bushed down to 1" (easier to handle the hose) I use have a threaded on both ends 2 1/2' section of steel pipe on both suction and return ends (to hold the hose in the barrels while pumping) with a cap to thread on when done pumping (to keep any oil in the hose from dripping out when done) And I carry plenty of old towels to wipe off the oil on the hose's. I try to be as neat as possible but you almost always have some drips of oil on the tailgate and in the bed around the tank.
Old 03-16-2007, 07:14 AM
kennedyford
Old carpet dresses up the back and is easy to throw away later. Hmm? Mine is blue
tasboj
28
10-27-2014 08:38 AM
Dave145
15
08-12-2013 10:13 PM
nstueve
13
10-25-2011 05:40 PM
Oxxon
2004 - 2008 F150
24
10-29-2008 08:58 PM
Hiflyer746
6.4L Power Stroke Diesel
04-01-2007 08:34 PM
Quick Reply: Collection Systems
