Normal Specs for MAF sensor in 5.4L Engine
Old 03-06-2007, 10:40 AM
jrroth's Avatar
jrroth
jrroth is offline
What is the normal operating band for MAF for the 5.4L engine. The MAF sensor is reading from about 0.8 to 1.5 #/minute per OBD2 diagnostic software. I am currently trying to diagnose codes P0171 and P0174 in a 2002 E-150.
Thanks in advance
Old 03-06-2007, 08:22 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Not sure of the spec's right off, have you cleaned the MAF yet? Have you checked the PCV hose elbows for cracks/leaks?
Old 03-06-2007, 11:38 PM
JRROTH1's Avatar
JRROTH1
JRROTH1 is offline
No - I won't have time to really work on it until this weekend. I just wanted to see what the MAF sensor was doing prior to cleaning it. I figured if it was reading normal then I might consider leaving it alone and checking everything else first.
Old 03-16-2007, 11:18 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
At what RPMs? And how much go-pedal?
Old 03-19-2007, 11:33 AM
jrroth's Avatar
jrroth
jrroth is offline
RPM are idle to about 2000 rpm under no load. Why go-pedal>
Jim R.
'04 F150 SuperCrew XLT 4x4 5.4L V8
'97 F150 SuperCab XLT 4x2 4.6L V8
Old 03-19-2007, 11:45 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Because the voltage varies depending on how much air is being drawn thru it.
greyst1
1999 to 2016 Super Duty
12-11-2021 07:53 PM
2000Ford2000
Modular V8 (4.6L, 5.4L)
12-03-2011 08:08 PM
PTL.PARKS
09-01-2011 07:39 PM
cedarbend
03-15-2004 06:24 AM
D
Computer Chips & Tuners
07-30-2001 01:09 PM
Quick Reply: Normal Specs for MAF sensor in 5.4L Engine
