spraying from the transfer case vent hose
i have a 1986 f250 with a 400 c6 1345 bg tranfer case. just recently i notice i am having alot of spraying coming from the vent tubing on the transfer case. this is getting all over my floor inside. does anyone know what my problem is and what steps i can follow to fix it. thank you.
it started sometimes once i hooked the tranny vac line into my vac tree on the intake, before then i had it hooked to the carb, i also fixed my heater inside my truck and hooked its vac hose to the tree, the speedo cable all of a sudden the speedo started to get real crazy and then only when on the free way then stop move completely, also went 4 wheeling got high center on a tree finally got off the tree and the truck hit the ground real hard coming off. aound all of this i notice a 2 inch crack in the bottom of my transfer case, leaks a little there but not much. i dont have the rubber boot bolted down on the 4x4 shift so fluid just comes all out from around there and runs all over my floor from there. i also notic it does it more on hight speeds. like between 55 75.
whiskeyrichard
1999 to 2016 Super Duty
51
03-05-2022 10:34 AM
FSSF
10-05-2016 10:09 AM
recluse
04-18-2010 05:25 PM
4onfloor
02-18-2010 04:26 PM
