AOD Front Pump Help
Old Feb 26, 2007 | 05:16 PM
Boss50's Avatar
Boss50
AOD Front Pump Help
I just finished rebuilding a AOD. The problem is that when I bolt the pump down, nothing turns. Turns fine without the pump though. I thought maybe a thicker washer under the pump might help but I'm not sure? I took the trans apart 3 times to make sure everything was seated as far down in the case as it should. The washer is the only thing I could think of that would solve this. Thanks for any help.
Old Feb 26, 2007 | 09:56 PM
stuart1's Avatar
stuart1
A thicker washer would only make things worse.
Start from the beginning.
What did you replace?
Old Feb 27, 2007 | 04:57 PM
Boss50's Avatar
Boss50
I replaced bushings, seals, clutches, bands, the usual rebuild stuff. There is a snap ring underneath the forward clutches(I think thats the pack I'm thinking of) so I know everything under the ring is down as far as it should be. I've spent hours checking to see if the top half fell down all the way. I don't know what else to look for.
Old Feb 27, 2007 | 08:12 PM
stuart1's Avatar
stuart1
Take it apart and start from the beginning.
You either have a washer out of position or a clutch plate that is not fully engaged.
