first broken truck
#76
#78
fixed
well i got my truck back on sat.at the shop for 22 days,mostly waiting for parts.they ended up replacing the high presure fuel pump.that was a cab off repair now i have a rattle and clunk from under truck when i go around a corner.i will live with it for a while.i am amazed at the amount of posts to this thread that had absolutly nothing to do with with what i started it for
#80
That's great you got your truck back! Cab off repair? The more and more I hear it's just so disapointing. Man I would try to get my money back If I were you! I hope the best for you, but I am sure you will be in the shop a lot with that truck! Is it worth it? I ask that question in all seriousness!
Is the 2008 Super Duty so much better than the 2007 that it's worth the potential shop visits that come along with it? I have not driven one yet just curious?
#81
Keep this in mind...the 2008 was designed to have the cab off during service to the 6.4L PSD. However, the 2003-2007 SD were not designed for the cab off...and the 6.0L PSD has had many a cab off a SD during service. I prefer something that is designed for it...then not.
Just my .02.
biz
#82
[QUOTE=scottman70]I hope the best for you, but I am sure you will be in the shop a lot with that truck![QUOTE]
Great post, NOT! Just what scientific data did you use to come up with this logic?
All mechanical products made by humans break for many different reasons. I fail to see the logic in your post or what it does to help the original poster with his problem. If you are just here to bash FMC or put down other posters on there choice of vehicle then maybe you shouldn't be posting around here. Your post is not only derogatory but also a backhand slap to the original poster. We don't need your type of posts on FTE.
FTE is a family friendly site devoted to helping each other learn and solve problems with there respective vehicle.
#83
KG Excursion
02-06-2015 02:16 PM
Green Meanie 85
05-04-2005 08:27 PM
