Best way to carry a MTN Bike
Old 02-20-2007, 09:10 PM
mbogosia's Avatar
mbogosia
mbogosia is offline
Hey guys, what is the best way to carry a mtn bike with me in my 6.5 bed? I would rather have some type of mount rather than just lie it in the bed. What do you guys think? Any pics would be greta also.
Old 02-20-2007, 09:26 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
I'm hunting one down for my Trek Fuel 98. I have been eyeballing some Yakima items that looks like they could do the trick... If worse comes to worse... I'll use a rec'ver hitch bike carrier. But something about dangling a $4K bike off the back of the truck worries me. So I think I'll continue to look to stay in the bed..
Yakima Racks
Old 02-20-2007, 09:51 PM
mbogosia's Avatar
mbogosia
mbogosia is offline
yeah, i am not going to spend $600. Isn't there a way to fork mount it to a piece of wood or something?
Old 02-20-2007, 09:59 PM
rpxr400's Avatar
rpxr400
rpxr400 is offline
Use something like this - mounted to a 2x6 or something. You can even screw it to the front wall of the bed.
http://www.nashbar.com/profile.cfm?c...%20Accessories
Another place is Performance Bike
http://www.performancebike.com/shop/...tegory_ID=4414
I've also just used tie-downs from the handlebars to the anchors in the bed. If the bike has suspension - even better - it will compress the suspension a little.
Old 02-20-2007, 10:07 PM
FTE Trigger
I suppose if you looked around and found a couple of pieces of small angle, turned on end with some mating holes for the fork...then mount that to something like the forward bedrail. It could work... With those 6.5' beds you'd be forced to remove the wheel (front) Otherwise it could work...
...Now only if Ford threw something like that in on their accessory/option line-up for the 150s...
On Edit: Yakima
Old 02-20-2007, 10:09 PM
mbogosia's Avatar
mbogosia
mbogosia is offline
Good links. Those are what I am looking for. Thanks
Old 02-20-2007, 11:08 PM
skybox's Avatar
skybox
skybox is offline
I agree with rpxr400, if you mount one of the fork mounts on a 2x6, 4x4 or even a 4x6 board cut to fit the width of the bed, it would not allow the bike to go anywhere, and you would not need to drill several holes in your bed. For security, screw in a couple eye screws into the 4x6 and run a chain through those and around the bike frame. Few people are willing to try to run off with a bike attached to a 5ft. long 35lbs. 4x6.
Old 02-20-2007, 11:43 PM
shawnfb's Avatar
shawnfb
shawnfb is offline
i have two of those front Fork mounts mounted to my flush truck box.
I pop the front wheels off, mount the front fork to the bike holder(s) and im off!!!!!
Works great! Looks ultra custom too, when the fork mounts arn't carrying bikes they can be used for tie downs. I haVE A black flush mount truck box and the bike fork mounts are black as well. I just drilled two holes for each bike mount into the truck box (no holes in the truck). The match is perfect!!
Ill post a pic soon
Old 02-21-2007, 04:09 AM
gui88ford's Avatar
gui88ford
gui88ford is offline
get a bike rack that goes in the hitch and if thats not an option then take a 2x4 and put thats in the notch in the bed then bolt a quick release to the 2x4 and attach the front tire to that....thats what i do with my 01 i have now and thats what i plan on doing to my new truck..
it's easy and cheap
Old 02-21-2007, 08:21 AM
shawnfb's Avatar
shawnfb
shawnfb is offline
how does the 2x4 stay put in a hard stop or bumpy ride?? I might anticipate a flying bike with tat method..
Old 02-21-2007, 08:52 AM
1-bigmac's Avatar
1-bigmac
1-bigmac is offline
I'd park the F150 and RIDE THE BIKE!
Old 02-21-2007, 09:23 AM
gui88ford's Avatar
gui88ford
it worked for me for years....thats how i always took my bike to the mountains....3 hr trip...i just put the 2x4 in the slot in the bed...attached the front forks to the quick release on the 2x4 and layed 2 bags of road salt over the 2x4 just so i didn't have to watch it and it didn't move....worked quite well
Old 02-21-2007, 12:42 PM
KevinM's Avatar
KevinM
KevinM is offline
Easiest way is to use the hitch mount bike carrier. I use a Thule and it works fine.
Old 02-21-2007, 12:53 PM
gui88ford's Avatar
gui88ford
thats true unless you have a trailer on the back like i usually do....i have a hitch bike hauler also and it is easy and folds away from the tailgate...nice unit but i can't use it all the time cause i'm usually taking my quad or something else with me and i'm not putting a cannondale on the trailer with a 900 lb quad....with my luck the thing will come undone and smash my bike...
Old 02-21-2007, 01:32 PM
mbogosia's Avatar
mbogosia
mbogosia is offline
I am staying away from a hitch or thule type rack just because of the money. I bought a truck and have this nice bed to haul stuff in. I really think I should use it and put my bike back there.
Quick Reply: Best way to carry a MTN Bike
