1997 F-150 ext cab, blender motor module
A local AC repair place just told me that my blender motor module is bad and needs to be replaced. 7.6 hrs of labor, $600 - is this true ?
All of a sudden my A/C started blowing warm and my heat started blowing cold. It worked fine then all of a sudden it started doing that.
Any ideas..
Any ideas..
Welcome to the forum cstein64
If it's the blend door motor that needs replacing it can be done without removing the dash. If it's the actual blend door then 7.6 hours is about right.
The first thing to check is the temperature control ****. They sometimes crack and then you try to adjust the temperature and the **** just spins on the control shaft.
rickbrad
15
08-05-2011 12:16 PM
neuera
21
05-02-2004 03:28 PM
